Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
Oven The oven will not heat up ,I set the cooking temp but the elements will not work.
Have you checked the circuit breaker? If it's not lined up with the "on" breakers, move it to the completely "off" position then move it to the "on" position. If it keeps flipping the breaker off, call an appliance repair person. Check the internet for reviews of your local companies to find the best one.
Posted on Sep 08, 2009
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Ge oven temp not correct after clean cycle
What are you cooking pizza. When you get at the high extreme most oven controls are not as accurate and have a wider differential. I assume the measurements are taken without opening the oven.
Dec 03, 2009 | GE Profile JTP56 Electric Double Oven
I have Range GE J34CFT 1 that is not heating up correctly
You have to start with putting an oven thermometer in the oven and comparing the oven temp with the temp that you set it to
Jul 21, 2009 | GE Kitchen Ranges
Fan but no heat
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
My GE XL44 doesn't heat up to full temperature.
There are several things to check.
1) check the broil element
The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
We rebuild these controls.
Regards,
Howard http://www.appliancetimers.com
Apr 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
147 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
