Question about Brother Disney PE-400D Computerized Sewing Machine
My rayon threads always shread while embroiedering on tshirts
When I use rayon threads to embroider on tshirts, they shread on in my upper thread guide and break. I have an Brother Inovis 4000 D embroidery machine.
  • hauprilea Feb 12, 2009
    I will try to leave the spool cap off and see what that does I feel like the thread would fall off. Does anyone know where I can get information on my Brother 8500D embroidery on how to download and rewrite embroidery cards
  • Brother Master
  • 1,133 Answers
Try groups in yahoo.com, there is one called Brothermachine embroidery , these user groups are usually a good place to chat with fellow owners.
Posted on Dec 12, 2011
  • 66 Answers
Make sure that you don't have any thead hung in the uptake arm also try useing it without the spool cap and see if that works I never use them because of that problem
Posted on Jan 29, 2009
Bernina Deco 330 embroidery machine bobbin case tension.
There are tests to perform for testing and adjusting bobbin tension. There really aren't any "specifications" other than adjusting it until the bobbin drop test is where it is normally recommended.
adjust bobbin tension Google Search
P.S.--be sure to ALWAYS raise the presser foot when threading the upper thread to insure the thread seats completely in the tension disk.
Aug 22, 2016 | Bernina Sewing Machines
How can I get my janome 11000 to work when embroidering? The bottom thread doesn't even show and top thread is always breaking.
The tension(s) may be too tight and could be threaded incorrectly. Start out with a brand new needle. Be sure to RAISE the presser foot when threading the upper thread. Consult the owner's manual to be sure it is threaded in the proper order. Test your stitch on a straight stitch and adjust it so both threads meet in the middle of the fabric. This setting works for straight stitch. However, usually the upper thread tension is loosened a bit for embroidery so the bottom thread will not show on the top of the fabric. Test it on some small embroidery patterns first until it's where you want it.
Mar 05, 2016 | Janome Sewing Machines
My upper thread is not feeding through the machine while embroidering. What could the problem be?
Install a brand new embroidery needle.
Remove the upper thread totally. Always raise the presser foot, then rethread from the beginning. Make sure you are threading it correctly. Test your stitch--just do a straight stitch on some scrap fabric. If it is still a problem, loosen the upper tension. Test again. If it hasn't improved, then there is possibly a piece of thread stuck in the tension disk or the tension disk is broken or faulty.
To clean the tension disk, remove the upper thread from the machine. Loosen the tension disk all the way and raise the presser foot. Dampen a piece of pearl cotton with rubbing alcohol and gently pull it down through the tension disk a few times. Rethread your machine, adjust the tension disk to the midpoint between high & low numbers and test again.
Jan 05, 2016 | Brother Pe700ii Embroidery Machine
Brother 780D will not feed thread through machine.
It is very important to have the bobbin case and the top tension both right. If the thread is getting stuck there is a problem. Always thread the top with the foot up. While threading make small pulls to make sure there isn't any places getting jammed. I've attached a rule document to help you to adjust the tension of the top and bottom.
May 20, 2015 | Brother PE-770 Embroidery Machine
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Brother Disney PE-400D Computerized Sewing Machine Logo
121 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
