Question about Office Depot Office Equipment & Supplies
Ativa AT-CC2008 out of alignment due to bent & broken casters
The back wheels of my shredder were broken off and one was dented inward by a moving company. I straightened as best I could and replaced the wheels but the computer read out states that the door is not shut even though it is. Assuming the computer is not damaged, is it possible to purchase the part with the casters that holds the basket?
SOURCE: ativa DQ120D shredder
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Posted on Jan 16, 2008
SOURCE: OM 99727 shredder not working
I had this same problem. This is what I did to fix it.
When I went to ShredCare.com (the recommended web site for technical support of this particular shredder), I read that 'Most models of shredders have a safety interlock switch that is activated by the basket.' Upon looking closely at my basket and the shredder, I found this safetly interlock switch and made sure to align it with the proper position within the basket. There is only ONE way to place the shredder on the basket and have this safety interlock switch activated. The switch is located on the underside of the shredder. Align this switch with the ridge on the inside of the basket. Listen carefully and you will hear the switch 'click' when in the right position. Mine is very touchy. I've even had to press in on the side of the basket while shredding to make sure that the ridge and the switch are making contact.
Hope this helps!
Posted on Dec 26, 2008
  • 35 Answers
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
SOURCE: Shredder won't turn on
I was using my Ativa DX180D and it was working fine. It just stopped and there was no power. I have tried all the plugs in the house but still not coming on. The basket is on properly and you can hear the click of the switch when you plsce the top on the basket. Any suggestions?
Posted on Sep 01, 2009
Ativa shredder manual
I could not find a manual or support on Ativa website but I searched their FAQ. It said that the shredder basket must be fully closed and integrated with the shredder. I had the same problem. I pushed the basket firmly into place and it stopped. I believe this flashing scheme may be telling you that the shredder and basket aren't properly aligned.
Oct 05, 2013 | Office Equipment & Supplies
Just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help solve problem?
The misalignment message is about the catch bin and the shredder! NOT THE TEETH!
Check to make sure the shredder is properly placed on the catch bin. There is a built in safetymechanism in the Ativa MD460. When the shredder is replaced "backwards" the safety pin is not tripped.
Look for a curve in the lip on the back of the shredder and align it with the bin. Worse case, just pick up the heavy shredder top, turn the unit around 180 degrees and put back down. My light came onimmediately.
Jun 16, 2011 | Office Equipment & Supplies
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
Took for allinement was told could not do because pass side wheel was pushed back 1.5 inches
Something is bent. The alignment shop should have told you what was bent. Could be lower control arm, spindle, strut, ect.
Dec 30, 2009 | 2000 Plymouth Neon
2007 DODGE RAM 1500 CASTER ON RIGHT SIDE WONT COME INTO SPEC GETTING SOME SHIMMY?? truck has 95,000 miles was last aligned with about 40,000 miles after a tire blowout and a bent rim alignment was...
The actual caster spec is not very significant - the handling is what counts. The caster will not cause a shimmy. Shimmy could be caused by tire problems, worn or damaged steering or suspension parts, bad shock absorbers or a bent wheel. As long as the vehicle does not pull and the handling is satisfactory, the caster is OK, If the tires are not wearing and the vehicle hamdles OK - don't worry about "specs." I have done a LOT of alignments where the readings did not match the specs, but the result was satisfactory.
Oct 25, 2009 | 2007 Dodge Ram Truck
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
Aug 24, 2008 | Office Depot Ativa DQ60M Shredder
ok " if the ready light did not come on it's telling you that there is no power sound like the plug in transformer is no good .
you can check that transformer , with a multimeter, see if you have the right voltage.
Jan 27, 2008 | Office Depot Ativa DQ60M Shredder
Shredder runs in reverse, but will not feed in auto.
The light beam from the photocell that checks if there stiil is paper to be shred is either clogged by paper dusrt, or there is still some paper pieces left in the shredder wheels. Remove it, or clean it.
Be sure to remove the power cord before attempting to clean, the wheels can easily chomp off your finger!!!
Jan 06, 2008 | Office Depot Ativa DQ60M Shredder
Ativa shredder
Pull out as much of the paper as possible. Then spray some window cleaner or similar on whats left to soften and disolve it.
Dec 29, 2007 | Office Depot Ativa DQ60M Shredder
62 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
