Question about Hardware & Accessories
How to set a drayton lp111si heating timer - Hardware & Accessories
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Got 5 year old drayton tempus 7 when i try to put the hot water on the main electrics tripout ,heating is working fine tho'
my very first check would be the thermostat on the hot water cylinder, you may find you have a water leak on the cylinder which is dripping onto the thermostat. (quite common) another check and this is very dependant upon your skills is to check the wiring to the timer.
Sep 04, 2011 | Heating & Cooling
Can you direct me to a user guide? I've moved to
The advance button send the current program to the next state. So if you have 3 on - off cycles programmed per day and you are currently at the second on cycle then by pressing advance the program moves to the second off part of the cycle and will stay off until the next on command time is reached. So if you are on Heating the advance will only affect the heating. Similarly if you are on Water then it will only advance the water program.
Sep 29, 2009 | Hardware & Accessories
Central heating on all the time!
The zone valve needs replacing.
Sep 24, 2009 | Water Heaters
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Boiler Thermostat
In desperation, I trawled the internet and am pretty sure that these are manufactured by Drayton, either a Drayton Digistat +2 or Digistat +3
Try this page http://www.gasapplianceguide.co.uk/drayton_central_heating_controls.htm
Good Luck!
Iain
Oct 02, 2008 | Hardware & Accessories
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
