Question about Kodak EasyShare M1033 Digital Camera
The camera seems to run out of charge quickly and then takes forever to charge. Also, everytime you turn the camera on...it asks for the date, etc to be entered
  • 979 Answers
Replace your batteries. It sounds like it has developed a short charge, thus depleting the charge quickly.
Posted on Jan 25, 2009
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
Oct 19, 2011 | Canon G12 Digital Camera
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Sep 12, 2009 | Canon PowerShot A520 Digital Camera
Power on Set up
Somewhere on the camera it will list and ask which language you want, check english on the list. Good Luck
Apr 27, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Camera battery seems to run out of charge quickly
It sounds like your battery is dead. If you get a replacement battery, it should solve both problems.
Jan 25, 2009 | Kodak EasyShare M1033 Digital Camera
Won't set date and time
Greetings bpm123,
My suggestion is to simply turn the date time stamp off in the setup menu. In reviewing the instruction manual, it appears you can obtain instructions on how to do this starting on page 21.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 24, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
I Have to Reset The Date an Time Everytime I turn the camera on
The following is from the manual which you can download on the link below: http://world.casio.com/qv/download/en/manual/ So it seems that you must either keep the battery charged or leave the camera connected to the USB dock (with PC on)! If your camera is not keeping the time for the 30 hours stated then it's probably time for a new battery.
Aug 08, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Polaroid pdc 4055
Take batteries out- leave for an hours or more re insert batteries and follow set up procedure in the manual
May 12, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
73 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
