Question about Car Audio & Video
Can i connect an alpine ai-net changer to my mitsubishi head unit with cd changer control?
    Scholar:
  • 116 Answers
I dd a preliminary check with Periphial and no go. Give me a year and model of the Mits and I can give you a definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
What are the switches for on the back of Alpine c da 9984
Those are for Ai-Net accessories (CD changer, amps, etc). If you're not using anything with Ai-Net, then I suggest you leave them as they are.
Feb 07, 2016 | Alpine Car Audio & Video
How do you activate the AUX function
This unit should recognize the connection between the deck and the changer without any problems. Are you sure the plug is compatible with alpine unit?
Sep 09, 2013 | Alpine TDA-7554
What is Ai net
ai net is simply alpine's upper level line of decks. they have their regular line and ai net line. just like kenwood has their normal line and their upper level excelon line. ai net uses different cables to connect with changers and aux items than the regular line.
Apr 18, 2010 | Alpine CDA-9883 CD Player
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Is there a cable that will hook up the cda 7839 to
No, the CHMS600 is not AI-Net compatible and thus your deck will not control it.
Aug 23, 2009 | Car Audio & Video
Installing a cd
you must have a cd changer via ai net it is just a screen controller not a cd player
Feb 18, 2009 | Alpine CVA-1004 Car DVD Player
Want to know if I can use the line-level inputs from the CD Chgr
Your alpine unit is the old "M-BUS" the other adapter you are talking about is an "AI-BUS" adapter. (Hence the model numbers beginning with CD"M" or CD"A" ...)
Look for an Alpine M-Bus to RCA Input adapter.
heres one on eay for less than 10.00 including shipping.
http://cgi.ebay.com/For-Alpine-M-Bus-to-stereo-RCA-adapter-cord-cable-8-pin_W0QQitemZ310117370938QQihZ021QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Feb 09, 2009 | Alpine CDM-7857 CD Player
Ipod connection instruction
you can get a set of phono leads with a jack on just one end?plug that in to the back of the head unit (depending on your pre out options and aux option) then plug it straight in to you ipod.
hope that helps?
Mar 08, 2008 | Alpine CDA-9851 CD Player
WONT READ CHANGER
You might have a pinched calbe try replacing it.
Sep 26, 2007 | Alpine CVA-1003 Car Video Player
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
