Question about Dell (55078) 145-Watt Power Supply
Packard bell R1004 does not charge
Battery and charger are ok, suspect power socket at back of laptop, can anyone tell me where to get a socket and how to change it all please?Also screen flickers when lid is moved, is this a screen fault or screen wiring fault?.I would appreciate any advice anyone can offer, thank you...
Hey there i have the same problem, found the power connector on ebay for £4, not sure if this will solve the problem but search for the model. good luck
Posted on Mar 30, 2009
My dell inspiron plugged in not charging
buy a replacement charger
if this does not work
i suspect the socket is perhaps damaged
sometimes its the laptops power management
so take the battery off
open the screen
press the power on
wait a few seconds
plug the battery back and the power
and see if the light flashes for charge again
i do suspect the charger or the laptops power socket...
Apr 19, 2015 | Dell Computers & Internet
Packard bell easynote new95 will not charge up or stay turned on. I have tried a new battery and charger but still have the same problem. Can anyone help please.
If you already have replaced your battery then you might need a new charger which is not charging your any battery at all.
Oct 28, 2013 | Packard Bell Computers & Internet
My Packard Bell Dot S netbook will not charge at all, unless pressured at a certain point. I have tried a new charger but no luck, what do I do?
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Nov 21, 2012 | Computers & Internet
My hp probook 4730s is having an issue, it will not charge. Could i bad charger or needing a driver update?
Nov 18, 2012 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
N500 will not charge
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 12, 2012 | Lenovo 3000 N500 Notebook
Will not charge easynote R1004 packard bell ac adapter ok
How long have you had it? Laptop battery life deteriorates greatly over time, and they generally need to be replaced after a year or two.
Nov 07, 2009 | HP Pavilion dv6000z Notebook
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Packard Bell Easynote R1802 Switch Off When Battery is plugged in
The battery is probably faulty, try a different one. If it does the same thing with a different battery, then must be a short in behind the battery socket on the laptop. In that case better take it to service.
regards
Mar 05, 2008 | Computers & Internet
Charging
If you can charge your battery in another notebook than borrow that notebooks power adapter & try it on your notebook with & without your battery in your notebook. Your power adapter may be devfective. Listed below is a link to your notebook. Included is all the updates for the,
Packard Bell Easynote R1935 Laptop
P/N : PB42B01001
http://support.packardbell.com/global/item/index.php?pn=PB42B01001&g=2000
please vote...
Feb 16, 2008 | Packard Bell (181379) Motherboard
Dell (55078) 145-Watt Power Supply Logo
128 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
