Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
HOW TO REMOVE ICE MAKER FROM SAMSUNG RFG297 - Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
Remove ice maker from samsung
Remove 2 screws in front and slide towards you to the front. Then disconnect connections
Feb 26, 2015 | Samsung RF265AA Bottom Freezer French Door...
Why does my ice maker not get cold enough to produce ice? I have a Samsung RFG297HDRS French Door refrigerator. Everything is functioning except for the ice maker. Water is getting into the ice maker
Ok Randy, Lets fix it.
My name is Peter. I am a retired refrigeration field service technician.
You are not getting cooling air to your ice maker freezer compartment. Once again Samsung - bad design - put a ice maker in the fresh food section.
So, you have a ice maker enclosed next to the fresh food section where the recommended temperature setting is 35-40 degrees F.
Where as your recommended freezer temperature is +2/-2 degrees F.
There is a air damper/vent from the bottom freezer in the back of your ice maker housing. Lets remove the ice maker to check for ice build up. On the left hand side of the housing on the wall there is a long narrow cover plate. This is where you connector harness is located. There are 2 screws holding the front end in and a tong and groove tab in the back. Remove the cover plate.
Now, pull the harness out.
Lets remove the ice maker assembly. There are two screws in the front end securing the ice maker to the top of the casing. These screws are recessed. They are either Philips heads or hex heads (1/4"). If they are hex head, he recessed hole diameter is small. Some hex head hand tools will not fit. A screw gun will work or a small outside out side diameter hex head hand tool.
Remove these screws. In the back in each corner is a tong & groove. Pull forward to release the ice maker. Using a small flat head screw driver wedge the wire harness to release. Set the ice maker aside.
Inspect the air vent/damper for ice build up. Use a hair dryer to defrost.
I do not believe you have a automatic damper controlled by a thermistor (temperature sensor). If you do, Remove the damper assembly. Get your multi-meter. Set your meter to the lowest Ohm reading (Omega on your meter) Touch the two probes on your meter together, you meter should read 1.0. Disconnect the 2 motor contacts. On the motor place one probe on one contact and one probe on the other contact. If the meter still reads 1.0 the motor is bad. If the meter reads 0-50 Ohms the motor is good.
If there is no ice buildup & the damper motor checks out, replace the temperature sensor.
You will find getting the wiring back into the side panel will be a little difficult. As usual, Samsung is not service friendly.
Oct 22, 2014 | Samsung RFG297HDRS 29.0 CuFt French Door...
How to reset 888 error code for samsung rfg297 refrigerator
888 codes are usually related to abnormal current feeds!
turn off fridge at mains for about a minute and back on to reset!
Oct 04, 2014 | Samsung RFG297 Black 29 Cu. Ft. French...
How to remove DA97-12317A ice maker from samsung RF263BEAESR? I've unplugged the harness, and depressed the clip but it won't pull forwards. Do you have to pull hard?
The instructions above are wrong. The ice maker will not come out as instructed. There is a tube coming out of the back of the refregerator that passes in and around the bottom of the ice maker that won't let it slide out. If you could take the bottom panel off the ice maker, you will see the tube. To replace the ice maker, the entire enclosure may have to be removed.
May 03, 2014 | Samsung RF265AA Bottom Freezer French Door...
Where is the ice maker reset button on a Samsung RS265TDRS?
This ice maker is on the door, so
remove ice bucket
move your fingers up under the ice maker tray guard on the left side until you find a button
you may have to press this several times, perhaps hold down firmly until you see some action
then quickly replace bucket & close door
Sep 06, 2013 | Samsung RS265TDRS 25.5CuFt Side-by-Side...
How do I remove the ice maker?
It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
z
Ice maker assembly upside down on bench.
May 03, 2013 | Samsung RF267AEBP
Samsung refrigerator rf26v ice maker
Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
Apr 23, 2012 | Samsung RF26VAB (25.5 cu. ft.)...
\how di I remove the ice maker on a RF226
2 screws at the front of Ice maker they are screwed to ceiling of freezer. remove and then pull IM to you. try the test button under the motor of the IM before you replace. just push it and wait. should start to cycle in a few seconds. if it cycles and fills with water your ok. then give about 2 hours to see if it dumps ice. make sure your freezer temp is set to -1 or your IM may not cycle. that is a samsung thing.
Jan 07, 2012 | Samsung RF265AA Bottom Freezer French Door...
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
I have a Samsung RF267ABRS french door refrigerator. It is two years old and it quit making ice. I have replaced the filter and the water dispenser works fine. I have also reset the ice maker. What can...
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Sep 03, 2010 | Samsung Refrigerators
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
87 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
