How to reset counter of canon ir6570
Printing machine canon image runner 6570
SOURCE: canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Posted on Dec 23, 2008
jell587
  • 447 Answers
SOURCE: reset canon iP 1600 waste ink counter
This link should help you with your problem.
Posted on Feb 21, 2009
SOURCE: canon 3300 image Runner
E000202-0001 solution
Posted on Aug 29, 2009
  • 13 Answers
SOURCE: What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
You should look at the 4 sensors behind the grey front plate, behind the front door, toner fall from hopper assembly on it and cause these codes ( each color cause a different code ), you should order a modified cable guide that protect sensors from toner and replace it after cleaning these sensors.
If the error code still appear you should change the toner supply motor ( each color have a different code ) or the PCB relay Kit (if i remember well you should also verify somme connectors on this PCB that can cause this problem)
Regards Mug71.
Posted on Sep 14, 2009
  • 110 Answers
SOURCE: counter wont reset after installing new imaging unit
One of the main chips has stoped working on the engine control board. So it does not blow up the fuse inside the Image unit and therefore can't reset the counter. Try changing the engine control board. part number is .. 116-1538-00
http://www.iteminconline.com/items.asp?Cc=7300P&ItemMoveby=0&Nbm=ZMD128%2FA&Pbm=119%2D6401%2D00&iTpStatus=0&Tp=&sTitle=&FromNav=False
Posted on Oct 02, 2009
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
Canon image runner 6570 error code E000732-0001
something wrong in DC Control to Scanner .
- check the scanner
- check the cables and socket between them
- or change the DC control
Apr 21, 2011 | Canon IMAGERUNNER 6570 Copier
Canon6570 printer Error Code E000012-0001. thanks!
sir i have a canon 6570 image runner
0001 code is coming again & again
plz ask me what i do
Jan 23, 2011 | Canon imageRunner C3100 Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Apr 08, 2009 | Canon imageRUNNER 3035 Black and White...
Printing on a Canon Image Runner 5000
go here and download the PCL5 driver for Windows XP (NOT THE 64 BIT version though):
http://www.canon.ca/english/index-softwaredownload.asp
The driver is the same regardless of the port. Just select "local" port when setting up.
Feb 13, 2009 | Canon imageRUNNER 5000 Copier
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
k24674
