Question about GE GBS22HCP Bottom Freezer Refrigerator
Explorer Gas Refrigerator
I have a Explorer gas fridge that the temp will only get down to about 40 degress....was wondering if anyone knew what was up with this? It surely isn't the norm. It was given to me and is only a few (maybe 5 to 8) years old. Any suggestions would be appreciated...Thanks :0)
Open the burner orifice up just a little , and i mean only a little, very little !
Posted on Nov 05, 2010
I have a 12 cubic foot explorer and have found that if the burner is not keep clean the effiency will go down. I also found that adjusting the flame to the lowest temp does not keep the fridge the coldest. Adjust the flame until you get an even blue flame with minimal yellow in it.You make the adjustment with the temp control.Also clean the chimney, I use a gun cleaning kit. Thanks Dennis
Posted on Aug 24, 2007
I have a dometic fridge fridge one side freezer the outher the freezer works great but the fridge just gets to 40 on electrcity and 48 on gas
move the temp sensor in fried down on coil or let hang run over nite if ok replace sensor if not disconnect thermistor from back board and try over nite of ok replace thermistor
Jul 05, 2014 | Dometic NDR 1292 Refrigerator
There is a small hairline crack on the outer casing of my fridge and a little bit of ice is forming on it on the outside is this dangerous?
The gases circulate at the back of a fridge in the thin metal pipes. If the pipes are ok, it should be ok but is probably costing you a fortune to run as motor will be on trying to keep temp down.
Feb 02, 2013 | Refrigerators
Need to turn off the door alarm on my srl551dp. fridge is working fine but refridgerator temp stays on 9 degress
Whats the serial number of the fridge Its on the top of the sticker in the fridge and on the sticker on the outer left side of the freezer
Mar 19, 2011 | Samsung Refrigerators
The oil pressure jumps up to the max when I give it the gas right now. Could that be because its 20 degress outside or should I get it checked.
It is related to the outside temp and the cold temp of the oil. Cold engines with cold oil will read a higher pressure. The pressure should go down to normal when operating temp is reached.
Jan 11, 2011 | 2002 Jeep Grand Cherokee
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Thermo King Super II SR BM#092170 will not lower its temperature... With temperature set at 40 degress... will not go lower than 50 degrees. Coil temperature is 68 degress.
try to clean gas cooler (it is radiator outside),unplug it from power (wall) then clean it with brush up-down (not left-right),wait 1hour and turn on
Jul 08, 2009 | Heating & Cooling
GE GBS22HCP Bottom Freezer Refrigerator Logo
171 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
