Heating the house causes breathing issues
Our home is 2 story 2400 square feet unit built in 2003 (DR Horton) here in Houston. When the heat kicks on the home gets immedately stuffy as if the heat is not balancing throughout the home. My wife and son immedately begin having breathing issues forcing us to kick the heat down and/or off. We have the ceiling fans pushing up in an effort to enhance circulation but we still appear to be having breathing issues.
Last winter we had similar issues and had a major HVAC group come out to inspect the home. They could not locate what the issue could be and said everything appeared to be OK.
What are we missing here ?
  • dvincent Jan 26, 2009
    My wife indicates she closes most of the exhaust vents upstairs 80 percent and opens the exhaust vents downstairs 100 percent during the winter. The house is a fairly new home so I am assuming it has a fairly modern system in the house. Wether it has a zone system I do not know.
  • Dale Koehn
    Dale Koehn May 11, 2010
    is every room in the house this way ? or just a few ? is there a zone system installed ? do you have fresh air intake on the system ?
    New Friend:
    Problem Solver:
  • 5 Answers
With the limited information, it is hard tp properly diagnose... DR Horton typically installs one unit on a two story and has it control all zones which is not the most effective means of HVAC. Homes are typically calculated, designed and "balanced" with the household doors open in order to get an even, balanced temperature to withing 2 degrees F. Heat rises and cold air falls - in open floor plans with the upstairs thermostat on the 2nd floor exposed to the downstairs heat rising upwards, this can cause an unbalance. If more definitive info can be provided, more specific info can help narrow down the issue.
Posted on Jan 03, 2013
  • 82 Answers
If your ducts come off the end of your supply plenum and not the middle this could cause a problem in that the air doesn't have time and a place to mix before it leaves the plenum to the ducts. should be at least 12" from ducts to the end of plenum. i find this problem alot.
Posted on Jan 26, 2009
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
What does it mean e5in air conditioner 48000 btu tlc
That's a 4 ton AC unit that should cool a 2000-2400 square foot home in most climates.
Jun 11, 2017 | Heating & Cooling
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little boxes.so in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
WeatherKing air conditioner. Numbers are off the unit outside. Inside units have Model #: WBEA-21 J1OSFJAI Serial#: TM2595 1510 and Model#: RCBA-4882GG21 Serial #:M1295. The house I have is 2100 square...
you should have a load calculation done on you house that way the a\c and heating system is right sized for the house to give you the best comfort and efficancy
Jun 18, 2010 | Weather King 10AJA6001AH Air Conditioner
The resistance heating will not heat my home above 67 degrees. what is my problem?
Are you trying to heat a house larger than 600 square feet? I think that your unit is to small.
Jan 04, 2010 | Amana PTH123B25AJ Heat Pump Air...
Water Heating does not work? The water does not heat inside the unit when washing... What can be causing the issue?
Not sure how long you have had this unit. The most obvious reason could be the heating element has failed.
After going over the problems described in horror stories by owners of this model of dishwasher, I am not sure if you will be able to get LG to service it at all.
Worth asking your local LG service centre if there is one.
Dec 19, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
