Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Goodmans 17pw22-4 power supply - Sony BRAVIA KDL-40S2010 40 in. LCD Television
Which power supply?
If it worked at all with the 12V supply, it probably wouldn't last very long. Don't recommend it.
Nov 29, 2013 | Televison & Video
Fuse keeps blowing on power board. It is the 3.15 amp fuse on the goodmans xpro tv
Most likely you have a short on the front side of your power supply. You will either need to have it repaired or replaced!
Oct 22, 2012 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans GTVL32W8HD power supply will not start up I have found the "ON" command is enabled OK from either manual button or Remote, but LED on front says red.??
Do find any bad caps, short circuits/parts on the power supply module? Do you get ON (PS_ON) signal at the power supply module. Try disconnecting connector from the power supply module that feeds the backlight inverter board to see if the power supply will put out the 12 and the 24vdc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 17, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodman outside unit not kicking on after power outage
If the outside fan works ,try to put a booster cap. in parallel with the capacitor , but if nothing works check the outside power supply box (or discennect) to see if a fuse is blown.
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodmans crt tv dead
there is another supply missing from your power supply, chec your components on that power supply a ht of 90volts is missing,
check all active components like transistors,diodes and resistors with very small values,
if you go through you are going to win that problem, ok.
Apr 03, 2009 | Goodmans 257NS 20" TV
I need a mains power supply for the goodmans GCE 5000 in car dvd player
Radio Shack usually have a good assortment of adjustable universal power supplies or try ebay.
Apr 01, 2009 | Goodmans GCE5000 Portable DVD Player with...
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
183 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
