Question about HP PSC 2210 All-In-One InkJet Printer
Remove and check cartridge
I keep getting remove and check cartridge on my printer. I have done so about 20 time I even cleaned them with distilled water and acotten swab, like the manual said. this is not helping at all. can you please tell me what i am doing wrong and how to fix it!!!
  • lepu Feb 14, 2009
    I have hp psc 2210 inkjet printer its showing display as remove and check the cartridge I have removed and cleaned the cartridge and again I am inserted even though it is showing like that only, what is the problem? Can you guide me any one.
    Genius:
  • 2,120 Answers
Out of ink.Replace all cartridges with NEW ones at the same time.
Posted on Jan 25, 2009
  • Leroy Elliott
    Leroy Elliott Jan 25, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
You can go to http://h10025.www1.hp.com
Type in buu02180 in the search block and click on arrow
Click on Hp Inkject product - Resolving Print Cartridge Errors
Follow the steps and see if you can correct the problem
Posted on Jan 27, 2009
Have cleaned the color cartridge and still says to clean color cartridge. Won't let me do anything just continues to say check the color cartridge.
Using distilled water on a cotton swab, try cleaning the carriage contacts in the printer. Don't keep the cartridge out of the printer for a prolonged period, or it may dry out and clog nozzles.
Hope that helps.
Sep 29, 2015 | HP OfficeJet 7310 All-In-One InkJet...
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
Replace ink cartridge
If the ink cartridges are brand new and you get this error then take it back to the store and demand a replacement. If your ink cartridges have been running a while then chances are that they are dirty...
Gather cleaning supplies:
Clean distilled water. Use bottled or filtered water if distilled water is not available.
Clean cotton swabs or any soft, lint-free material (coffee filters work well).
Remove both cartridges.
Unplug the printer.
Lightly moisten the lint-free cleaning material with clean water.
Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty.
If that does not work then I would try ordering some new cartridges from a trusted source.
CANON PIXMA INK CARTRIDGES
Sep 12, 2012 | Canon PIXMA MP240 All-In-One InkJet...
HP officejet 6210 all in one...message is"remove
Hi Jim,
When you install a new cartridge, be sure not to touch the contacts, and make sure the contacts on the cartridge align with the contacts on the printer, and all packing tape has been removed. If the contacts on the printter are coated with dry ink, you should clean them with a cotton swab and distilled water. Dampen the swab and wipe off the dry ink on the contacts and let it dryt. Also, run the cartridge alignment on the new cartridge.
I hope this helps. Let me know if you need further assistance.
Randy
Feb 09, 2012 | HP OfficeJet 6210 All-In-One InkJet...
How do I clean the printer head on ly HP J5780 all in one
Hello thanks for using Fixya
In
HP Officejet J5780 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is important to use the appropriate technique. The things you need is "Cotton swabs" & "Distilled water"
Now follow this procedure
  • Open the front door of the printer, located below the scanner lid, by swinging it down. The print cartridges will move to a position where they can be accessed
  • Unplug the printer to prevent the cartridge dock from moving away from the center of the printer. Press an ink cartridge down until you feel a "click" then pull it out of the dock.
  • Dip a cotton swab in distilled water and use it to clean any built-up ink from the metal contacts on the ink cartridge and from the area around the ink nozzle. Avoid touching the nozzle itself, which is located in the center of the bottom of the cartridge. Discard the cotton swab if it becomes dirty, and use another to continue cleaning. Keep cleaning until the ink cartridge is no longer dirty, then set the ink cartridge aside.
  • Remove the second ink cartridge and repeat the cleaning process. Set both cartridges aside until they are completely dry
  • Replace an ink cartridge by holding it slightly below the dock, then pushing it up and in until it snaps into place. Do the same with the second cartridge. The black cartridge is inserted into the right slot on the dock, while the color cartridge is inserted into the left slot.
  • Close the front door of the printer, plug the printer back in, and turn it on.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | HP Officejet J5780 All-In-One InkJet...
I need to clean the printer cartridge jets. How do I do this
In
HP PSC 1210 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is important to use the appropriate technique. The things you need is "Cotton swabs" & "Distilled water"
Jan 26, 2011 | HP PSC 1210 All-In-One InkJet Printer
I refiled cartridge but my priner saied it is emty and refuse to work
Clean the problem cartridge contacts
  1. Gather the following items to clean the cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product from the electrical outlet.
  5. Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the cartridge contacts.
    CAUTION: Do not touch the ink nozzles. Figure 6: Cartridge contactsc00832021.gif
  7. Clean the contacts in the carriage, inside the product. Figure 7: Carriage contactsc00246272.gif
  8. Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge.
  10. Reconnect the product to the electrical outlet.
  1. Close the product cover.
Figure 8: Print Carriage contactsc00427144.gif
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP Photosmart 2575 All-In-One Printer,...
Have hp deskjet 6540 printer. yellow light on right side under x keeps blinking not printing. Am I out of ink?
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
Aug 24, 2010 | HP Office Equipment & Supplies
How do you clean the print heads?
To manually clean the cartridge, get a bunch of cotton swabs or lint-free cloths and some distilled water. Remove the cartridge (one at a time and do not keep them out for more than 30 minutes) Lightly moisten a swab and squeeze out the excess water. Wipe the copper contacts on the cartridge until no ink or dust appears.
I hope this helps.
Apr 25, 2010 | HP DeskJet 5650 InkJet Printer
What do I do if my printer says 'clear cartridge'
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  6. Clean the cartridge contacts. CAUTION: Do not touch the ink nozzles. Figure 6: Cartridge contactsc00832021.gif
  11. Close the product cover.
c00246272.gif Step three: Repeat reseating and cleaning stepsIf the problem is not solved, repeat the reseating and cleaning procedures above.
Apr 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
