Question about Bell Sports Electra I Love <3 My Townie Bicycle Bell
Chain guard replacement for Townie bicycle
Where to buy chain guard replacement for Townie bicycle
Where to buy a chain guard replacement for a kids bicycle brand name "mini viper 16 inches wheels diamondback."
Any bike shop that deals with Diamondback should be able to order you one.
Feb 02, 2016 | Cycling
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
What is the cover called on the crank
Sounds like it is a chain guard. Chain guards are cosmetic to a bicycle and do not affect the functionality of a bicycle being operational. You will probably be just fine without it. In fact, you never see a bike used for racing with a chain guard, it's just extra weight to haul around.
Sep 28, 2015 | Diamondback Joker BMX Bike White 20-Inch...
Two banging sounds with each rotation
Most beach cruisers have a chain guard. There is always a slight "wobble" of the front chain ring, check to make sure the chain isn't slapping the chain guard. The chain guard can be adjusted. The chain also might have loose tension causing it to bounce around just enough to hit the chain guard. The opposite may be true, if the chain is too tight, you could be getting a popping sound at certain points on the chain as it messes with the gear teeth, in this case loosen the chain slightly to put a little slack in it.
Jan 14, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Missing chain guard
If it's new and should have the guard then go and change it,if not from a bike shop buy one.
Mar 31, 2011 | Hot Wheels Kmart 12" Boys Bike
I recently purchased a 20"
The chain guard is usually fastened to the seat tube of the bike (the frame tube coming up from the pedal area to the seat) with a plastic band. If this band is broken or missing, and there is excessive play in the chain guard, I suggest removing it entirely or returning the bike as it may be a hazard.
Mar 15, 2011 | Mongoose Cycling
I just bought a La Jolla 26' men's bike and the pedal stem is scraping on the chain guard. How and where do I make adjustments?
Examine the top of the chain guard where it mounts to the bicycle. Loosen the fasteners enough to slide the chain guard in and out. Adjust it so it doesn't hit the crank or rub on the chain and tighten the fasteners back down.
Jan 19, 2010 | Cycling
Where to buy chain guard "prowheel 0503-IS-481-2"
This is hard Try
Mikesbikes.com
DansComp.com
bikeParts.com
Jul 18, 2009 | Mountain Prowheel Bicycle Crankset Bike...
I am trying to replace the chain on a swinn pixie bike--but thereis a chain guard that is giving me troubles--I need to know how to assemble the chain with the guard
see if theres a master link on the chain and take off from that way you dont have to take off the guard. the master link will look diffrent from all the other links and can normally be removed with a screwdriver
Jul 02, 2009 | Cycling
Bell Sports Electra I Love <3 My Townie Bicycle Bell Logo
297 people viewed this question
Top Bell Sports Cycling Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
