I received a new bell remote 1707A-DKNFSK03 which will not control my 5900 receiver. It controls the TV ok but not the satellitre
Old remote works but it is in bad shape
3 Suggested Answers
SOURCE: How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Posted on Oct 17, 2010
SD Tech
  • 14553 Answers
SOURCE: I need a code for a Prima Q328 Television
It may not be possible as that remote has a limited number of codes and even if it programs may only do a few things.
Try all the possible codes and look to see if that remote has a search feature which would allow you to try each and every code it has.
Posted on Nov 08, 2012
My remote for my bell 5900 is so worn out that when I press down on the buttons the remote does not work properly. I've tried new batteries and I literally have to wiggle the buttons to change channel
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 12, 2015 | Bell Televison & Video
I am having trouble finding the device code for my panosonic SC-XH150. I have a telus satilite Tv remote. The model I believe is IC:1707A-DKNFSK03 or 194009. It's a 6.4 IR/UHF Pro. If anyone has the proper...
. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
May 05, 2014 | Televison & Video
Bell expressvu receiver
If you are using the OEM Bell remote to control your Bell receiver, the remote may have failed.
Jan 17, 2014 | Televison & Video
Nov 07, 2012 | Televison & Video
My old Bell receiver 's remote was an IR Remote. How do I program the new UHF PRO Bell remote?
mikecrans175
I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and Hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote:
  1. Go to System Info screen.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Mar 14, 2011 | DISH Network IR Remote Control
I would like to control my dish network receiver 3100 with my samsung remote
trifonas_ger
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
May 07, 2010 | DISH Network 32 Ir 137180 Remote 5900 3100...
My remote is not working. On the back it says 6.2 IR/UHF PRO Canada: 1707A-DKNFSK03 139779 It used to work fine, then I had to change the batteries and it no longer works. The lights work but nothing...
The switch that selects what type of remote style (UHF or IR) is probably the culpret.
pull the battery cover and take out the blue tab
Play with the switch unitl it works and put the tab back in (the tab is supposed to select the right value for you but it may not be properly aligned.
i was about to toss mine but this worked.
Dec 24, 2009 | Bell SH50102 Remote Control
Oct 13, 2009 | Bell Televison & Video
Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Feb 14, 2008 | DISH Network IR Remote Control
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
