Question about Sharper Image SA260 CD Shelf System
Broken amplifier for Sharper Image DECO ZipConnect stereo
We have a Sharper Image Designed DECO ZipConnect stereo system with AM/FM/CD Stereo plus ZipConnect for iPod & MP3 Players ZE401. We've narrowed down the problem with the amplifier portion of this shelf system. Since Sharper Image has gone out of business, we cannot find anyone to repair this component. We like the system and think it will be an easy fix...any ideas on where we can get this repaired?
SOURCE: Sharper Image SA260 Stereo Shelf System
open the stereo doors and switch the line button on the bottom right from out to in
Posted on Aug 01, 2008
SOURCE: instruction book for a micro cd shelf system
not solved - but not going to pay for an instruction book when it should be a 'downloadable' item by sharper image
Posted on Dec 06, 2009
SOURCE: Sharper Image Cd shelf system model # SO227
The one I troubleshot had a bad 4700 uF 25v capacitor next to the dc connector on the main pc board. this dc connector cable runs from the rear cover of unit(the rectifier board).When I power up the unit,dead,no standby lite no power.I removed all connections to cd board and just left the mmain board and display board connected.clock and standby came on,but after about two minutes the 4700uf 25v power cap started to smoke (and dmm read 12v and falling across cap).hurray that was my big clue! Replaced cap with a gang of 5 1000uf 35v nichicon electrolytes in a parallel L package formation to fit the realestate of old cap and allow cover closure.happy tunes.Unfortunatly made by cheapos who spec counterfiet electrolyte formulated caps.Watch out for "S.I." brand electrolytics.Check temp of rest of caps while running unit as this beast is chock full of them.
Posted on May 28, 2010
SOURCE: Sharper Image 3-CD model SA248 Doors opening problem
The bands that allow the cogwheels to turn, snap and needs to be replace.
Posted on Nov 27, 2010
SOURCE: Problem with the Sharper Image
You need to simply replace the 'belt' in the gear drive of the door. Go to a shop where they fix CD's. Just went today and he found one in seconds...no charge, if you can believe it! Measure the belt by strectching end to end and multiply by two.......or take the old one with you. Got one TODAY, as a matter of fact and now just need to have all 4 discs play. :)
Posted on Nov 26, 2011
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
Why cant I get volume to come on, dont have a remote
If there are no volume buttons on the device, and you know it is switched to the correct source, then yes, you'll need a remote.
Sep 11, 2014 | Sharper Image Slim One-CD Stereo with...
I need to know what type antenna it needs
What you need can be as simple as a "dipole antenna", or as complex as an FM antenna on your roof. A dipole antenna looks rather like the letter T, with the top part of the T about 3' wide, and the base part long enough to reach your set. Make it out of lampcord, extension cord, etc. The connection looks like this:
the vertical bars are connections on the ends of the "T", and the base connects so it all makes a loop. The size isn't really critical.
You can buy one for under $10
May 06, 2014 | Sharper Image Slim One-CD Stereo with...
Clock setting
you just make sure the original remote present. Start by Pressing menu on your remote control and you can navigate from there.
Oct 16, 2013 | Sharper Image Slim One-CD Stereo with...
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
Light
You need the remote to turn that light off.
Jun 09, 2008 | Sharper Image Slim One-CD Stereo with...
Apr 09, 2007 | Sharper Image SA260 CD Shelf System
Sharper Image SA260 CD Shelf System Logo
216 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
