Question about Sony PlayStation 2 (PS2) Console
Controller stick replacement
Hey Guys, My controller left stick is not working any more, it doesn't return to center. I know that the stick can be replaced, I already sent 2 controller for stick replacement. I have 2 broken PS2 controllers, that I can remove the sticks (they look good).I wanna know if it is that simple to replace the controller stick (just weld a new one in place)? Also I would like to know if there is difference in left or right stick: can I put a right stick in a left one? Thanks!
    Problem Solver:
  • 13 Answers
OPEN IT AND SEE IF ITS SOME THING IN THERE IF THERE IS NOTHING IN THERE BUY A NEW ONE FROM WALMART THEY ARE REALLY CHEAP THERE WELL GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jul 14, 2007
SOURCE:
Character is looking left
I've known some controllers have a problem with analog sticks constantly turning left, seems to be a calibration issue with older joypads. Try centering the pad as you switch the console on, and if that doesn't solve it, its new controller time!
Oct 15, 2012 | Aspyr Call of Duty: Black Ops Mac
My ps3 controller doesn't respond to the ps3, all
If the controller is Sony you can just go the store you bought it at and exchange it But if u got a controller not Sony brand then recommend you not to buy cheap brands bc they break fast . Buy Sony products will last longer
May 12, 2012 | Sony Video Game Consoles & Games
My lbp character wont move, when i try to walk the Right arm is only moving? Hos do i fix it?
It sounds like you may have a problem with your controller. Pressing the L2 button and moving the left analog stick, which also controls walking, will result in SackBoy moving his right arm (left as he's looking at you.) If your button is stuck, it will override the walking function. Try holding down the L2 button and releasing it rapidly. Hopefully this will snap back the rubber contact pad back into position. If this doesn't work, try a different controller if you have access to one. As a last resort, you can try disassembling the controller, if you feel comfortable doing so, and making sure that the contact pad is in correctly and not bunched up and also that the return spring has plenty of bounce. Hope this helps. Have a good day!
Jun 08, 2011 | Video Game Consoles & Games
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
When I try to play a game (Call Of Duty WaW), it won't let me look up, and makes me spin around. I thought it maybe was the Look Inversion in the options, so I changed it, but then it only let me look to...
If you spin around that means the right stick is being pressed in a direction without you even touching it because of loss of calibration. There are some calibration utilities online but for the start you can let Windows calibrate your gamepad.
Open control panel -> classic view (on the left) -> Game Controllers -> Select your controller -> Properties -> Settings tab -> Select Calibration and follow the instructions. If during calibration you see that the right and/or left stick is being pressed in a direction, it is a hardware issue. In such cases replacing the controller is a better option. If it is still under warranty you can get it replaced. If you bought it from Game stop they do normally accept returns within a month or so.
There is one thing you can that sometimes works: Press the right stick towards right and turn it fast in a circle all the way through clockwise. Repeat it 3-4 times and then do it anti clockwise. It works for me each time my controller acts like that, I dont know how but it doesnt matter. Hope it works.
Apr 04, 2010 | Microsoft Xbox 360 Controller
We just recently purchased the wireless Logitech PS2 controller...my son has games which you can zoom in and out...but the controller is stuck ZOomed in and will not return to normal w/o having to pull one...
You need to recalibrate the the analog sticks. To do this you need to take out one of the two batteries then press and hold L1 and L2 at the same time. While holding L1 and L2 insert the battery you took out earlier. Now you can release the L1 & L2 and your analog sticks should be centered. Do not touch or move the analog sticks during this process. If this fails to recalibrate then repeat the procedure again.
Mar 19, 2010 | Logitech Cordless Action Controller for...
My wireless xbox controller keeps blinking green but won't connect
Have you tried leaving your console OFF first, and then Holding down the CENTER [X} button to turn your console on?
Usually that always works, I usually disconnect the battery clip and reconnect it (to turn it off) when it keeps blinking and does not connect.
Then I hold down the center button on the controller and move the left analog stick around in circles while it's blinking, and it usually recognizes it a lot faster when I do this.
-If the above does not work, disconnect the battery clip on the controller again and put it back in,
-But first (before powering on the controller) press and hold the tiny -sync- button on your xbox (while it's on),
-and then turn on your controller, and hold down the sync button on your controller, and move the anolog stick around while it does this also.
If the above does not solve your problem, I'm sorry, but I tried.
Jan 17, 2009 | Microsoft Xbox 360 Controller
MY CONTROLLER
For everyone:
go here and see if you can make controller RMA, which means you'll send them your controller, and they'll send you a new one.
Oct 15, 2007 | Sony PS2 Dual Shock 2 Controller...
Sony PlayStation 2 (PS2) Console Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
