Question about GE Profile Wizard DPSE592EAWW Electric Dryer
GE dryer model DDSR475ET0WW, need dryer belt - GE Profile Wizard DPSE592EAWW Electric Dryer
    Problem Solver:
  • 14 Answers
Follow this link for your part:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=207614
I got parts from these guys really fast. Repair went very well.
Posted on Jan 25, 2009
GE Dryer knuckle
Check belt and or belt tensioner. Gets dust and lint contaminanted and eventually goes bad ?
Mar 10, 2014 | GE Dryers
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
Need a diagram on how to string the belt on a 1998 GE electric dryer, model # DJSR473ET6WW. We are trying to install a new belt.
Repairclinic.com has some excellent dryer belt diagram illustrations you can refer to. Just click on the "Repair Help" link at the top of the page. Next, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down until you find GE. If you have questions, please let me know. I hope this helps you.
Dec 31, 2009 | Dryers
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
GE Profile Wizard DPSE592EAWW Electric Dryer Logo
138 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
