Question about Go Software Inc. PCCharge Pro (100PROL0000SER)
Pc charge pro error 75 - Go Software Inc. PCCharge Pro (100PROL0000SER)
When i open the camera and want to use the zoom and press the zoom in button amessage saying lens error 0*2119 appears and the camera swithes off
You need "digital zoom" switched on. Go to the menu and then into the "settings" section. One of the settings will be "digital zoom". You will have to enter into that setting and set it to "ON".
Dec 28, 2014 | Pro Power PRO SERIES Equivalent PENTAX...
My nikon d40 has a problem, on the lcd it says shutter error
hi
even if camera says shutter error, most of case are defective sequence unit (SQ unit). however shutter problem or sq unit would be charged around $75 to 235 depend on what your local repair shop want to charge.
usuallly nikon would charge more on general problem. it is batter to bring to local repair shop like those type of problem.
Thanks and best regard!
May 23, 2011 | Nikon Cameras
Run time error 75
error 75 is a path/file access error try running as admin...
Apr 15, 2011 | Sharp XE-A404 PC Desktop
I have an acer aspire one .The problem is that it's battery dfoesn't get charged over 75% even after prolonged charging.
This shows that the battery is not healthy enough to accept 100% charge and is only healthy enough to accept 75%.
The solution is to claim warranty support on the basis of a faulty battery, if you have not had it long.
The alternative option is to purchase a replacement battery, you may even get one that holds more charge. A 6cell will enable you to use your laptop longer than that of a 3cell.
Thanking you
damnor01
Apr 11, 2011 | Acer Aspire One D250 (99802378332) Netbook
Have a Dell D810. Battery at 75% charge. When I
Get a 90w adapter is the only resolution. The D810 on a 65w adapter will:
  1. Disable the battery charger
  2. Run slower due to throttling
The 65w adapter MAY charge the battery if the computer is not running (Not sure on that)
Jan 25, 2010 | Dell Latitude D810 Notebook
Run-time error 75 path/file access error
please open your application through run as option
Oct 01, 2009 | Sharp XE-A404 PC Desktop
Whirlpool double oven model number RB270PXY0 needs control panel replaced. Cost of repair??
If you need the entire control unit replaced, i found one online for roughly 300 bucks. This can be done by yourself, its time consuming and requires special attention. If you hire a pro, they may charge upwards of 75 bucks an hour, they may also charge a fee if you purchase the control panel outside of their company. like most car mechanics will do. Im not sure how long it would take a pro to install the new unit but im sure it would be at least 2 hours. so figure in everything and you could potentially be looking at around 600 if a pro did it. Hope this helps!
Sep 23, 2009 | Ovens
Run time error 75 path/file access error what
yours operating system files would be courpted so kindly format yours machine with windows xp service pack 2 and then watch the performance.
Jul 18, 2009 | Sharp XE-A404 PC Desktop
Sharp XE-A41S - Customer Support Tool Run-time error '75':
you have to run the program as administrator. left click on program icon to bring up menu
Apr 07, 2009 | Sharp XE-A404 PC Desktop
Go Software Inc. PCCharge Pro (100PROL0000SER) Logo
Top Go Software Inc. Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Avishek Samaddar
Avishek Samaddar
Are you a Go Software Inc. Computer and Internet Expert? Answer questions, earn points and help others
