Question about Durabrand 5.1 Surround Sound Computer Speakers
I cut a speaker wire
I accidently cut one of my speaker wires, and can't fix it. Is there anyway I can fix it? Is it possible to order only one replacement speaker?
  • 101 Answers
Well I have in the past been able to strip the rubber back to the bare wire on both ends and then twist them together. use electrical tape to cover any exposed wire this should fix it.
Posted on Jan 25, 2009
How to change speaker wires?
Depending upon where and how thoroughly the wire was chewed, you may be able to cut out the bad section and splice the remainder.
Jul 05, 2014 | Panasonic SC-PT660 Theater System
My left speaker has no sound unless i jiggle the cord right at the part where all 3 p;ugs turn into 1 cord. how do i fix it?
The wire inside the speaker cable is broken. You may be able to identify the exact point the wire is broken by bending the wire and unbending the wire. If you can locate the approximate location of the break, you could cut the broken section out then strip the wire, and reconnect. Best to solder if possible. Otherwise, you will probably need to replace the cable or buy a new speaker set.
May 19, 2014 | Logitech X530 5 Speakers
Rear Speakers cutting out
You Need to Change Wire Connected to Speakers. it's may be damaged internally.
Mar 15, 2014 | Panasonic Audio Players & Recorders
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
My volume control box is broken, how do i fix it?
Just anyway to gain access to open the box is ok there is no easy way really remove the screws (If) it has any or cut an access hole to reattach the wires just dont damage the speaker is all that needs to be watched for. Remember to rate my solution
Apr 26, 2012 | Logitech X-530 Computer Speakers
Shorted Out a JL Audio E4300 Amp
The screw through the speaker wire caused a dead short and turninged it up loud, you may have fried the capacitors on the output side of the amp circuit. It is easy to tell if you open the amp up, but do so with it disconnected and out of the car. The tops of the caps may be split or bulged. It is worth fixing in my opinion.
Feb 12, 2012 | Car Audio & Video
Saturn ion not starting in cold weather
We cut the white wire on my son's 2005 ION and followed a youtube video. He said to remove the airbag fuse first. After we cut the wire and put the airbag fuse in, now the airbag light is on. I can't get it fixed for beans. So now he has a security light and airbag light on. He has been in several accidents and the airbags never came out anyway so I guess he will have to drive that way. It did start last night no problem in 30 degree temperature!
Jan 15, 2012 | 2005 Saturn ION
I have a Technics SU-V460 integrated amplifier, and the left channel (speaker) keeps "dropping" out . I have to turn the volume right up in order for it to "kick" back in. Would this be...
There are three possible problems with your system. The first, and cheapest to fix, is that the wire connecting the left channel is faulty. To test this, unplug the wire from the back of the amp and put a new one in, then play some music BEFORE putting everything back into it's respective place. If the speaker doesn't cut out anymore, problem solved! Speaker wire is very cheap too. If the problem persists, try connecting one of your other speakers that you know works to the input. If that speaker cuts out as well, then the amplifier is the faulty component. That will cost some money to repair (between $50-$150 depending on where you go, excluding the price of a new amplifier). If the speaker you know is not faulty works when plugged into the left channel, then the only other option is that the original left channel speaker is faulty. This could cost between $25-$100 to get repaired, excluding the cost of a new speaker. It will not be as costly as a new amp, but will definitely cost more than a new speaker cable.
Mar 03, 2011 | Car Audio & Video
Acs90 Wire fixed to the speaker has a short, is there anyway to get the speaker open? I can splice wires if I can get to it...I think.
To get the speaker open you will have to get a long shaft #1 phillips
screw driver blade. You may have to order the blade from Amazon if
you can't find one locally.
Jan 12, 2011 | Altec Lansing ACS 90 Computer Speakers
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
Durabrand 5.1 Surround Sound Computer Speakers Logo
269 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
