Question about Samsung Refrigerators
SAMSUNG RSH1DBRS WATER DISPENSERS DRIPS
WATER DISPENSER DRIPS
  • 163 Answers
SOURCE: GE TPX24 BRBJ side-by-side drips water from door dispenser
water valve is behind ref.on either the right side or left but you will see your water line going to ref.water valve.Most likely replace.
Posted on Mar 06, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
Sea Breeze
  • 4654 Answers
SOURCE: built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
appliancepartsoutheast@live.com
Posted on Aug 10, 2009
  • 105 Answers
SOURCE: in-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Posted on Nov 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Water dispenser drips how can I fix it?
There are two possibilities. The water control valve is leaking while off or the water has air bubbles in the supply line. If you just recently changed the water filter and the air has not been completely purged this will cause a drip until the air is out. You can also remove the water line at the control valve and see if it continues to flow. Just us care by unplugging refrigerator first. Be right back with part numbers, Sea Breeze
Posted on Dec 22, 2009
Our Samsung Fridge Freezer model RSH1DBRS is leaking water into the bottom of the fridge area - we have tried defrosting but it is still leaking - anything we can do?
Do you have water dispenser in the door? If you do the water holding tank in the refrigerator could have a crack in it and is leaking, I just recently had to replace the tank in my refrigerator
Nov 26, 2016 | Samsung Refrigerators
The water inlet valve needs replacing. It's located in the rear of the refrigerator and can be accessed by removing the cover (either cardboard or metal). The water line is attached to the water inlet valve. You can order the part online or purchase one from a local dealer.
Mar 08, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Door dispenser drips
I am assuming when you say the door dispenser drips, that you mean the water dispenser. I had the same problem with my Samsung fridge Freezer, it just turned out to be that the water pressure from the tap supplying the dispenser was turned up too high, the advice I was given (from an engineer) was to turn down the pressure a little then run the dispenser for approx half a litre, then let it sit for a while to see if the drip continues, if it does, try again, it took a few adjustments but we're running fine now, but don't forget, it's normal for a dispenser to drip once or twice after its use. Good luck.
Jun 17, 2012 | Samsung RF265AA Bottom Freezer French Door...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Mar 06, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Fabric softener leaks out at beginning of wash
I have a 9200SQ Whirlpool duet.  It might be similar.  I think the bleach and fabric dispensers work on the siphon principal--once the level gets above a certain point they will then siphon out until almost nothing is left.  They should not start to siphon until extra water is directed into them during the correct cycle.   It is possible that they are starting to siphon early because 1. the washer is not level, 2. water is being added to the dispenser during the wrong cycle 3.  You put too much liquid into the dispenser and it started the siphon.
Note:  You should not peek in the dispenser during the washer cycles because it might interrupt the "siphon"action and leave residual bleach or fabric softener in the dispensers.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
