Question about West Bend 41053 Bread & Dough Maker
Rubber coated bearing around the mixing shaft wore out
Too much friction is building up causing the mixer belt too smoke and the paddle not to mix.   where can I get a replacement bearing assembly and the cost.  If I clean the bearing out it works good for that time.
The seal is worn out due to heat and wear over time. Unfortunately, you probably cannot replace the seal without having to replace the entire breadpan for a cost of about $35-40. I've had to replace mine twice over the past 8-9 yrs and will be replacing it again within the next month. I bake a loaf of bread every day or two.
Posted on Mar 07, 2009
Can't get the mixing paddle to come out. Directions say to turn off, tell head back, press beater upward turn left. Done this and still won't come off.
Try and get some CRC or similar into the connection so that it can get between the planetary driving shaft and the paddle. Elbow grease and muscle is what is going to free it up. Twist & turn until it frees up. Once you get it off polish up the shaft and scrape the hole clean with a knife or similar. There will be a black build up in the paddle hole. Flour gets in there and works itself into the alloy creating that black crust that locks the paddle onto the shaft.
Mar 23, 2018 | Food Mixers
Mixing paddle slips off pin
We have never heard of this problem before. I spoke with our KitchenAid technician as well and he has never seen this problem in the over 20 years of working on KitchenAid mixers.
Are you sure that the beater is hooked on all of the way, and there isn't anything in the beater stopping it from turning and clicking into place? Is the pin stuck? If the pin is not sticking out all of the way, or the spring is bad/damanged it is possible the beater could come loose. You would want to replace the agitator shaft.
Agitator Shaft: http://www.mendingshed.com/kacentershaft.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 03, 2013 | KitchenAid K45SS Classic Stand Mixer
It is not mixing all the way. Nothing is jammed. 3 loaves now have not come out, because clearly it hasn't been mixed thoroughly, like it used to. No burning motor smell.
Hi and welcome to FixYa, I an Kelly.
This can be caused by a few things.
1. Check the bread kneading paddle(s). Make sure that it fits properly and is not slipping on the drive shaft. Also look for cracks in the paddle blade hub.
2. Check the bread pan coupler and drive pan bearings (link is a picture reference only of a USED part. http://cgi.ebay.com/Breadman-bread-machine-TR2200-Parts-Coupler-/200535459633?pt=Small_Kitchen_Appliances_US&hash=item2eb0d84731 (klunking sound usually noted if this part has failed)
3. Inside the bottom of the unit check the belt tensioner. (Picture reference only!)
http://cgi.ebay.com/Breadman-bread-machine-TR2200-Part-Belt-Tensioner-/200535465293?pt=Small_Kitchen_Appliances_US&hash=item2eb0d85d4d
Usually if there is a belt or tensioner problem you will note a lot of rubber pieces in the bottom of the unit.
Thanks for choosing FixYa,
Kelly
Feb 06, 2011 | Breadman TR2200C Ultimate Bread Maker
Can I stir the batter before the baking cycle? I am following the recipe-sometimes it mixes well and other times it doesn't.
Hi, If it is not mixing well it could be three things. 1) Make sure the bread pan is inserted in the machine correctly. 2) The paddle is sticking. 3) The belt is loose. Take the pan out and see if you can turn the paddle freely by hand. If yes ok. If no, the sealed bearing that the shaft goes through is failing. If everything is ok then check the belt that turns the motor shaft. Motor and belt is located in the base of the machine. Be sure to unplug machine before checking the tension of the belt. Hank
Aug 01, 2010 | Sunbeam 5891 Bread Maker
Timer went off and I went to get what should have been a finished loaf of bread. What I found wad a loaf cooked kind of hard in the middle and lots of uncooked dry mix all around the outside rim. It looks...
Hi, Sounds like the paddle inside the bread pan did not mix the ingredients very well. Take the pan and paddle out of the machine and see if you can turn the paddle freely by hand. Yes is good..if it sticks then the sealed bearing is failing. Next, keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft turns. The belt may have fallen off or is too loose and the paddle won't turn freely under load. The belt, pulleys and motor are inside the base of the machine. Hank
Mar 15, 2010 | Breadman TR2200C Ultimate Bread Maker
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
The mixer blade won't mix. The motor runs but blade won't go.
Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
Hank
Sep 14, 2009 | Oster Kitchen Appliances - Others
Sunbeam 3500s
It seems the kneading paddle isn't spinning. Clean out the pan and take it out of the machine. Put the paddle on the shaft and see it it spins freely. If it does not, then the shaft is stuck or the bearing is frozen.
Next keep the pan out of the machine and start the bread maker up. Look through the clear top and see if the shaft is spinning. If not then the drive belt is broken.
If paddle is okay, and belt is okay, then the motor is broken.
Hank
Aug 25, 2009 | Sunbeam Kitchen Appliances - Others
Bread paddle isn't "strong" enough to knead
Hi bex_ta,
If the paddle doesn't have the power to knead, you're probably losing torque at one or more of several points:
1) Where the paddle attaches to the shaft (is there evidence of slippage/wear in the paddle socket?),
2) Where the shaft goes through the pan (possible friction point - presumably this is what you oiled)
3) The belt might be slipping, either due to friction in the shaft, or because the belt is worn and loose.
You need to determine if the shaft is sticking, and if it's because it's bent (fairly unlikely) or if there's something fouling it. You'll need to isolate and fix that first. If you can rotate the shaft freely, then we look at (1) and (3) above - these are simple parts replacements, but the shaft would be more involved.
Belts are getting tough to find - if you can provide specs/measurements, I'm going to start contacting a small-run manufacturer to see about making some new belts, as I'm seeing multiple online requests for belt parts. If you happen to have a broken one, I'd like to get one as a sample to send to a manufacturer.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 08, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
K45 started smoking while mixing cookie dough
There is the possibility that if the mixer is 30 years old and it has never been serviced that the gasket around the gear case is leaking oil and in that case it would not be hard to get liquids on the armature or the stator as the gear grease in the transmission is vegetable base grease and it separates into liquids and solid and when the head is tilted up the failed gasket allows the separated oil to leak down and to the rear onto the mixer right onto the motor parts. It maybe nothing more that cleaning out all the old grease and re-packing and adding a new gasket.
Dec 14, 2007 | Food Mixers
Kitchen Appliances - Others Logo
224 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
