Question about Acer Aspire 5350 5750 5750g 5750z Series Power Board & Cable
WHEN START SCAN IT ASK FOR WIA DRIVER.ASPIRE 5750 WITH WINDOW 7
  • 1,511 Answers
You are missing the program that scans material from the scanner to the computer. Look for your Printer/Scanner at the manufacturers web site. Go to the Support and Drivers. Download the updates and/or current program and install it on the computer. If it is an HP; they have a special programs that can look for HP hardware and go directly to the page that has the essential programs necessary to operate the printer/scanner. In short; all hardware needs DRIVERS to communicate by and between the hardware and the computer.
The other method is to go to Control Panel/Devices and Printers. Work from there to make ceratin you have a setup already installed.
Posted on Dec 30, 2013
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
Need driver for 4470c scanjet for window 7
Hi zanggerf !
Hp doesn't support your unit anymore since Windows XP . Here are 3 workaround solutions :
solution one:
You can get your unit working in WIA mode if you can follow this :
make sure your XP ( yes XP ) driver is correctly installed .
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP PrecionScan Pro , program will hang .
solution two :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
solution three :
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
Have a nice day ,
Best regards,
Fanaudi .
Feb 13, 2011 | HP Scanjet 4470c Flatbed Scanner
Need wia driver for windows 7 32 bit. factory drivers don't work
In any case , make sure the factory driver is correctly installed . If there are no driver available under W7 , install driver XP .
Download and install Freekapture ( http://download.cnet.com/FreeKapture/3000-2094_4-10711598.html )
Load FreeKapture , clic on Scan and select WIA-Canon DR2020U .
Hope it helps ,
Regards
Jan 04, 2011 | Canon DR2020U Flatbed Scanner
Trying to load CanonScan N124OU onto Windows 7 and get error message "there is no application registered for this event"
canon scan n1240u will work on Win7
here's how:
go to this site: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
click "Drivers and Software" then select OS "Windows XP" then download "WIAdriverN670UN676UN1240U.EXE"
Install the WIA driver on your Windows 7 OS and used only mspaint to capture image on the scanner
TWAIN doesn't work on Win7 but WIA still doesGood Luck!
Dec 06, 2010 | Canon CanoScan N1240U Flatbed Scanner
I have a Xerox Phaser 3100MFP. It will print, but will not scan. Help...
have you installed scaner driver WIA SCAN DRIVER
and have you installed paperport v11
if not install paperport v11 and wia scan driver from"http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3100MFP&Xlang=en_IN&Xcntry=IND"
Aug 21, 2010 | Xerox Phaser 3100MFP/S Laser Printer
How do I scan a photo into my computer?
you can use the generic windows scanner wizard which can be found under ...
My computer ----> WIA Canon MP620 (double click)
many graphics programs also have scanner utillities...
Illustrator CS2 or Photoshop 7 ----> File menu ----> import
good luck
rate if useful please
Oct 26, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Will not scan only
We will need to ensure the scanner is being recognized correctly. We would suggest checking the DEVICE MANAGER for any conflicts.
Get to the Device Manager by:
1. Right-Clicking on MY COMPUTER
2. Left-click on PROPERTIES.
3. Click on the HARDWARE tab, then DEVICE MANAGER.
In the Device Manager please for the following:
1. Any yellow or red X's, question marks or exclamation marks.
2. Under the Category of Imaging Devices - Check for Epson Product name.
If IMAGING DEVICES is listed, test the scanner from PAINT. If IMAGING DEVICES is not listed then the scanner is not being recognized. We would recommend trying another USB port or cable.
To scan in paint:
1. Click on START > ALL PROGRAMS > ACCESSORIES > PAINT.
2. Click on FROM SCANNER OR CAMERA.
3. Choose COLOR PHOTO.
4. Scan.
It is possible your Windows Image Acquisition (WIA) service is not started.
To start this process please follow the steps listed bellow.
1. Click on Start, go to Control Panel.
2. In the Control Panel window you will Performance and Maintenance, please left click that option.
3. Next we are looking for Administrative Tools, please left click on that option.
4. We are looking for the Services icon please left on that icon.
5. In the Services window we are going to scroll down to the bottom and look for the Windows Image Acquisition (WIA) Service, Please Right click it with your right mouse button.
6. We want to select the STOP option with your left mouse button.
7. Next we want to Right click on the Windows Image Acquisition (WIA) service again and select the START option with your Left mouse button please.
Jun 12, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Bad images
Hi, please try the following solutions below to resolved that issue:
1. Trash & Reinstall scanner driver. You can go to http://support.epson.com to download the updated driver for this scanner.
2. Check conflicts on Device manager.
How to get device manager:
a. Right-Clicking on MY COMPUTER
b. Left-click on PROPERTIES.
c. Click on the HARDWARE tab, then DEVICE MANAGER.
a. Any yellow or red X's, question marks or exclamation marks.
b. Under the Category of Imaging Devices - Check for Epson
Product name.
To scan in paint:
4. Scan.
It is also possible that Windows Image Acquisition (WIA) service is not started.
Jun 11, 2008 | Epson Perfection 2450 Photo Flatbed...
Acer Aspire 5350 5750 5750g 5750z Series Power Board & Cable Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
