Question about Kenmore 73952 Gas Dryer
No electricity to the ignitor
It is a gas dryer. Kenmore 110.97566200
ok so all sensors work and have continuity, the fuse is not blown. The voltage on the ignitor is very low, it wont light up a tester but on a meter its sensitive to pick up some. the motor runs but it looks like the line coming from the motor to the ignitor is the source of malfunction. any suggestions on what would cause this?
  • pilotgbaker Jan 26, 2009
    i tried that there was still no response from the ignitor for electricity. is the ignitor in these models supposed to be on all the time?
  • pilotgbaker Jan 27, 2009
    the ignitor is fine continuity and visibly. could it be the coils that control the ignitor?
  • 640 Answers
Since it seems you know what your doing,,,when you disconnect the ignitor and turned unit on you did not get 110 im asusuming,,,now ,,i want you to jump the iginitor sensor dont use a meter just put the 2 wire together,,the white and the blue make sure therte not touching anything but each other...that the little glass sensor on the side of the flame box ,,on left hand side...onthejob
Posted on Jan 25, 2009
  • onthethejob1
    onthethejob1 Jan 26, 2009
    no only when call on by cycles..just checking this is a gas dryer,,,ahhh did you check the ignitor it self,,,look closely at it and look for a burn spot or crack ,,use flash lite...onthejob
  • onthethejob1
    onthethejob1 Jan 27, 2009
    yes that was next,,,vavle no 1 that the 1 withe three prongs ,,1 prong goes to ignitor,,if you have to just purchase that 1..onthejob
Number 59 is the fuse. if it is blown due to air restriction or vent blockage the dryer will run but no power will be transferred to the gas assembly. If you are indeed getting power to the gas assembly you want to first check the flame sensor for continuity. If it is open the ignitor won't glow. If the sensor is good check the ignitor itself is what I would do next. The following videos show how a gas dryer works and How to get into the type dryer you ahave which is a 4 wheel drive type,
4 wheel drive electric dryer like yours:
Gas dryer how it works:
Oct 28, 2012 | Kenmore Dryers
I have a Kenmore gas dryer model 110.77670400. The ignitor lights, but gas valve doesn't open. I tested thermal switches in back for continuity and all checked good. Flame sensor is good and I replaced...
Thank you for contacting fixya.com.
If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer.
Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them.
Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires.
Please get back to us if you have further query else please accept the suggestion.
Jun 15, 2011 | Dryers
Dryer will not heat up
Unlike electric dryers gas dryers will continue to run if the thermal fuse is blown. Usually some sort of air blockage will cause the thermal fuse to blow. The control thermostat powers up the gas assembly.cd79cfa.jpg It judges the drum temp as air passes over it on its way out the exhaust. It opens(quits sending electricity to the gas assembly) at 160f for cotton and closes(starts sending power to the gas assembly) again at 105f.
When the dryer is running and the timer is set for heat, the control thermostat is energised. It powers up the flame (ignitor) sensor, the ignitor, and the solenoids. The gas does not come out with those solenoids energised because the ignitor is using most of the power to get it lit. When the ignitor is glowing wide open the heat from it causes a bi-metal in the flame/ignitor sensor to bend and open the circuit to that ignitor. That kills power only to the ignitor. The resulting power surge causes the solenoids to yank open them flood gates and raw gas comes out onto that screaming hot ignitor. KAWOOOSHHHH Houston we has ignition. At this point the ignitor becomes a safety device. As long as the flame is washing through that ignitor the current keeps flowing to them solenoids and the gas keeps a coming. If for some reason their was no ignition the ignitor would cool down and shut off the solenoids. More here
Jul 25, 2010 | Whirlpool WED5520SQ Gas Dryer
No glow from the ignitor. what is the voltage coming in to the ignitor (gas dryer 110-736932100) could the heater relay be the issue?
all you have to do is check continuity across the ignitor. does it have continuity? if no you need to check your thermal fuse for continuity? it is a white peice with 2 wires going to it and sits on the blower houseing. if no then it could be your timer. or yes it could be your flame sensor. that sits off the side of your flume tube where the ignitor is. but highly likly it's just your thermal fuse.
May 15, 2010 | Kenmore 73932 Gas Dryer
How do you relight the pilot on a kenmore 80 series gas dryer?
Their is no pilot light. The system uses a glowbarce9a48b.jpgOPERATION
The newer dryers use a silicone carbide ignitor for ignition. If the Fuse is ok482c508.jpg the gas assembly gets power from the control thermostatfa8083a.jpg. The flame sensor allows the ignitor to go cat go. The coils themselves10e9e78.jpg cannot open the gas because the ignitor is using a lot of power. When flame detectc5ddc7a.jpg gets warm enough then it shuts down the ignitor and power is redirected on the other side of the 3 prong coil. The ignitor is not finished. It now is hot enough to act as a path to the secondary coil which energizes and sends that raw gas to the 1800f screaming hot ignitor. Igniton occurs and keeps the ignitor hot. If ignition at this point were to fail the ignitor would cool down and shut off the power to the secondary coil. Clever ain't it? So what can go wrong? Worn out flame sensor takes longer to reset, ignitor open. Clogged vent012c9c0.jpg overheat fuse blown, bad thermostat, and faulty solenoids.If all is good it should continually shut on and off all during the cycle to regulate the heat
May 09, 2010 | Kenmore 72062 Gas Dryer
I replaced the igniter and thermal fuse and dryer
The thermal fuse should only be replaced if the dryer will not start
If it starts the thermal fuse is good.
If you touched the ignitor with your fingers it may have blown out.
Open the dryer and check for voltage to the ignitor through the ignitor wires while the dryer is on.
If you have no voltage check the hi-limit thermostat for continuity as well as the operating thermostat.
Check the flame sensor for continuity while it is cold.
If you have power to the ignitor place a clamp on amp meter on one ignitor wire and turn the dryer on.
If you read 3 amps or less the ignitor is bad.
If it reads the amps or more the gas valve coils are bad.
Jan 17, 2010 | Whirlpool Dryers
My dryer dont dry
Possible causes depend on the dryer model and type. Electric dryers work diffeently from gas dryer.
Both electric and gas dryers usually have a thermal fuse located at the back of the appliance. Check if thermal fuse/switch is blown or tripped , and eventually replace it.
If the fuse is ok, and appliance is running but not drying, then next part to test will be the thermostat.
A dryer thermostat can be tested using a multimeter , set to read impedance at RX1. If the thermostat is good, it must have low Ohms at room temp, and return no continuity (infinite ohms) at temp. limit.
At this points things are different depending if dryer is gas or electrical.
On a gas dryer test valve , fan and ignitor.
On electric test the heating element and fan.
On both gas and electric, last part to be tested is the timer control board. If all other parts are fine, go for the timer board.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a kenmore 80 series gas dryer. it's not staying hot. sometimes it will and sometimes it doesnt. i replaced the ignitor on it and its still not working what do you think?
This is probably the gas valve not working right. I would replace it. The ignitor is working and turning on the valve but it doesn't stay on.
Sep 03, 2009 | Dryers
Kenmore 73952 Gas Dryer Logo
54 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
