Question about Dehumidifiers
I'm looking for a humidity controller for my wood's dehumidifier;were can I get one?
Cust P/N 3-70106-002
3 Suggested Answers
  • 4736 Answers
SOURCE: My dehumidifier is not working.
I'd say you're right on target. In which case, although the unit was manufactured my Whirlpool for Sears under their house brand, Kenmore. You can find the part(s) online at Sears Parts Central
http://www.searspartsdirect.com/partsdirect/index.action . If you can do the replacement yourself, you'll really save $$ on labor.
Hope this helped you. Please let me know. Thanks.
Posted on May 30, 2011
vko007us
  • 254 Answers
SOURCE: the dehumidifier is 7 years old. It runs, but I
PLZ try this link for ur support:
http://homeappliance.manualsonline.com/support/maytag/dehumidifier/instruction-manual-3294618
Posted on Aug 20, 2011
What is rightsettingto set at
the general accepted Rh for the avg home is 70% Rh
this is dry enough to not promote mold growth but wet enough that all your wood surfaces wounlt dry out and crack
Oct 19, 2014 | Danby Premiere DDR5009REE 50 Pint Capacity...
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
What is the proper setting for the Temp &Humidity?
Set the temp level at whatever point your home's temperature is now. Lower the humidity level to 35%. If you don't have an LED screen on your unit, set the manual control to maximum.This way, you will extract the maximum amount of humidity and make your home more comfortable.
Jun 29, 2011 | Fedders A7DH45B2A Dehumidifier
My dehumidifier is not working. The control panel lights-up, but its stuck on 70% humidity and won't adjust down. I took it apart and noticed burnt marks next to the circuit that controls the humidity....
May 30, 2011 | Kenmore 54701 Dehumidifier
Have classic dehumidifier model#CDR4500E. Can't adjust it automaticaly to come on or shut off. Don't understand the keypad fuctions, booklet to confusing.
Your dehumidifier preset default humidity level of 70%. Which is rather high, if you're using the unit in the hot Summer months. You can override this setting and lower the humidity level in increments to as low as 35%. Which is ideal during hot, humid weather. The Air Down button lowers the humidity level.Once the level is set, the unit will cycle ON and OFF as necessary, to maintain the level of humidity.
I have looked at the Owners Manual for you unit, and it's very thorough. But, I can understand, if you're not familiar with how the units work, it could be confusing. Page 5, is very informative on how to operate the unit, as far as setting humidity levels, which is what's important. If the operation of the unit continues to be a problem for you, contact Danby Customer Support 1-800-263-2629 and they can walk you through the procedures, while on the phone with them.
Hop this helped you. Please let me know. Thanks.
May 18, 2011 | Danby DDR2509EE Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
Unit runs but doesn't collect water and there is a lot of water in the basement. Have had dehumidifier for two weeks and was working well before.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. Also, it's not uncommon on some dehumidifiers for the fan to almost run constantly. It's designed to keep the air moving, in a effort to detect when the humidity level rises.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter no is the time to check and clean it. And while your at it, clean the cooling coils too. Since it sounds like this unit has been working hard for 2 weeks.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 15 to 25 minutes and check the water collection bucket. If there's water in it, it's working as it should.
For more information on the proper operation of a dehumidifier, go to the Tips section of Fixya and look up "Taking the confusion out operating a dehumidifier".
Hope all this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Dehumidifiers
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
