Question about Jandy Ae2500t 115,000 Btu Heat Pump
High Refridgerant Pressure
My Jandy AE 2500T heat pump says "high refridgerant pressure". What does that mean and what do I do about it?
Thanks,
Norm
I was able to find the manual online which had the solution in the troubleshooting guide.
Posted on Jan 26, 2009
What is the pressure switch on a Jandy pool water heater AE-Ti
it tells the unit that the filter pump is working if you dont have voltage to both sides either bad pressure switch or plugged copper line
Dec 29, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Error code High Ref Pressure on a jandy AE 3000T-R
Make sure your water filters are clean and if you have an external by-pass, make sure it is not open. High Ref Pressure is normally caused when the refrigerant is not cooled off by the pool water circulating thru the heat exchanger. If your filter pump is not circulating enough water (normally around 40gpm) in the system then you will trip the high pressure sensor. If the HP sensor trips without the compressor engaging the try replacing the sensor.
Oct 26, 2012 | Jandy Pool & Spa
2000 Buick LeSabre a/c clutch will not engage. Fuse is good, can't tell if micro relay is ok or not, no power at compressor clutch plug when a/c is turned on. Are there other switches (full throttle...
There is a low refridgerant pressure switch, and a high refridgerant pressure switch. Either can cut the power to the clutch. You will have to check the pressure in the system to know for sure.
The electrical part in the clutch could be bad. You could run jumper wires to the clutch connector to see if it will engage. If not, its the clutch. If it does engage, then more than likely your just low on refridgerant, and possibly have a tiny leak.
Aug 29, 2011 | Buick LeSabre Cars & Trucks
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Need to charge a/c cant find port
Keep following the refridgerant lines until you find the low pressure connector. Sometimes it is tucked away in a difficult place behind the engine near the firewall. Make sure you've found the low pressure connection. DO NOT try to force refridgerant into the high pressure connection.
May 10, 2009 | 2001 Ford Expedition
High side low side pressures don not respond to freon levels
Chances are you have a TXV already installed. Thats why simply adding refridgerant is not effecting the pressures.
All you are doing by adding refridgerant is overcharging the unit, and possibly forcing the compressor to try to pump liquid instead of vapor. Not god for the compressor.
If the vibration noise is your only problem, I would try emilinating the vibration.
Find where the lineset is touching other parts of the house and install vibration dampening opads there. If the airahndler is mounted to the structure of the house, install vibration reduxction pads there too. If it is suspended from the floor joists you may have to change that mounitng method.
You can suspend the drain overflow pan and then set the unit in that on dampening pads, or set it on blocks from the floor/crawlspace.
Check your data sticker to find out how many pounds of refridgerant the unit takes.
By now, you are probably way overcharged.
Dec 11, 2008 | Ruud UAKA042 Air Conditioner
I have a frigidaire package heat pump,in heat mode it goes into defrost everytime it runs for a few minutes,no matter what the outdoor temp.is..it runs about five minutes or so and goes into defrost for...
That is usually caused by either lack of airflow through the outdoor coils. (Dirty coils, need cleaning)
Bad defrost board. (needs to be diagnosed with multimeter and extensive explinations and/or experience to be sure)
Low refridgerant, causing premature freeze up and in turn causing frequent defrost cycle. (Recharge to proper pressures with proper refridgerant type. Requires EPA certification for use of refridgerant, you would also need refridgerant guages, temperature reading device, and refridgerant.)
Dec 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Jandy Ae2500t 115,000 Btu Heat Pump Logo
402 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
