Question about Teledyne Laars Pool & Spa
I have a Laars model pw-1825 the burner turns on then turns off I checked for continuity and I have none, is the control board bad?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teledyne Laars Master
  • 1,448 Answers
Check the flame sensor it isnt showing rectification
Posted on Nov 12, 2014
I have a kenmore elite range model no. 790.9911. The right front burner wont turn off. Is it the switch, burner or control board
On this model (with the glass touch controls, right?), it is usually caused by a bad, sticking relay on the relay board, located on the back side of the oven, down near the bottom. Some of these models had a safety recall... You might want to check to see if yours is one of the affected models. (The model number you gave is not complete; find the complete model # & serial # on the range itself, usually on the range frame, visible when you open the drawer or open the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 13, 2014 | Kenmore Kitchen Ranges
My pilot turns on but the burners never start up after I turn on the switch on my Teledyne 2 Pool Heater. Any suggestions on whether the burners may be clogged or defective or if it is the switcÉ
You have a bad flame sensor or a bad burner graound... the gas valve porves the flame by passing a very small current through the pilot flame... yes flame does conduct electric...if the sensor is dirty or bad or the ground wire to the burner is corroded the gas valve does not sense the current and "see" the flame.
heatman101
Aug 13, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Rheem imperol 80 pilot light turns on but the burners will not light
HAVE YOU TURN THE GAS VALVE TO ON WHAT MODEL DO YOU HAVE HAVE YOU RAISE THE TEMPETURE CONTROL IF YES THE GAS VALVE OR THE IGNITION CONTROL ARE BAD
Nov 29, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Main Burner Will only stay on with mid range temperature setting
Thermostat is bad. There is a micro switch behind the dial that reacts to the temp probe and you may try cleaning it out first but in my experience replacing the t-stat is usually required.
Jul 04, 2009 | Jandy Laars Lt 250,000 Btu Heater
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Pool & Spa Logo
57 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
