Question about Kenmore 43142 Front Load Washer
Rocking and VIbrating
We had our Kenmore 43142 washer hooked up yesterday, and balanced professionally on the pedistals. The trouble with our washer is that it is on the second floor and has to be placed inside a special tray incase of leaking (so it doesn't ruin the floor/ceiling below). However, in running a few loads yesterday, the washer shakes so violently (does not stop cycle), that it shakes the whole house, so much so we can feel it all the way on the main floor. Any suggestions? I am at the point of thinking it might have to be moved into the basement, which I would like to avoid as I would have to pay to have a hook up installed, and pay to have the appliances moved downstairs.
  • Katie Simon Jul 17, 2007
    We are trying to decide what to do right now, the builder is coming over to see if they can come up with a solution, but they said that moving it to the basement wouldn't be good as it has a concrete floor. I thought concrete would be the best spot for it as long as we have a rubber mat under it? Any suggestions?
  • 67 Answers
As long as you have it on the second floor there really isnt anything you can do to fix it anything you do will probably make it worse there is only one washer i know of that is front load and acts decent on the second story and thats the new samsung with the roller bearings. Sorry to tell you but u will probably end up moving it to the basement
Posted on Jul 14, 2007
SOURCE:
My tumble action washer spins out of balance no matter if it is leaded with clothes or not
turn the tub by hand and see if it wabbles if so only one fix replace inner tub.
Sep 28, 2010 | Kenmore 43142 Front Load Washer
My Kenmore front load washer just bgan to goes out of balance
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Kenmore 43142 Front Load Washer
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Oct 03, 2009 | Kenmore 43142 Front Load Washer
Vibrating with or without clothes as if out of balance
Vibrating or rocking? try pushing the drum around manually in the washer front back right left.re check level.
Jan 23, 2009 | Maytag Performa PAV2200
Washer is off balance for a kenmore elite quietpak he4t How do you level washer?
adj all 4 feet all the way in..try to rock washer adj front feet as need to give washer as solid footing as possible tighten lock nut in top position against washer bottom ..adj only as much as need ..the further out the feet are the more likely the washer is to vibrate ..a weak floor is the biggest reason washers vibrate ..if washer is on a pedistal be sure the for screws holding pedistal to washer are tight adj pedistal legs same as washer feet so bottom of pedistal is as close to floor as possible
Sep 19, 2008 | Washing Machines
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
LG Front Load Washer
try leveling it, i had a nut that come off under the washer i had to put back on now it runs great
May 17, 2008 | Kenmore 43142 Front Load Washer
We just installed a new whirlpool front loading duiet sport washer and dryer , It keeps going off balance it was installed by the store . we have had the service man out twice now , he is no help at all....
floor may not be as solid as you think.remove pedistal drawers make sure the screws holding pedistal to washer are tight 2 front and 2 back going into bottom of washer frame next adj legs so bottom of pedistal is as close to the floor as possible you may have to lossen the lock nuts to do this next try rocking the unit by hand and adj front legs as needed to stop motion and and give washer a solid feel retighten lock nuts up to bottom of pedistal
May 05, 2008 | Washing Machines
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Have you switched the power on? you could try a radio or something in the socket. Have you turned on the water valves? Tom.
Feb 28, 2007 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
125 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
