Question about Activision Guitar Hero III for Nintendo Wii
Red Drum wire is broken
The wire from the red drum and the circular plastic piece under the rubber are both broken. Just got this for Christmas for my kids. Any replacement drum heads available to buy???
  • 1 more comment
  • eatyler1 Jan 25, 2009
    Son twisted the organe symbol until the wire broke. Tried two different wire splices no help. Need new symbol wire.
  • helpamyjo Apr 12, 2009
    Someone twisted our cymbal so that the connecting wire pulled out of both ends.  We need to order a replacement part.  Help!
  • Anonymous May 02, 2009
    wire pulled out of the plug that goes into orange drum - buying a new drum really won't help
  • 32 Answers
YOU CAN FIX THE WIRE PROBLEM . AND DRUM CAN BE PURCHASED OFF EBAY OR AMAZON.COM
Posted on Aug 28, 2009
Noticed plastic slivers in the drum and under the rubber boot.Is the from the drum being unbalanced
Could be that the 'spider' mount for the drum is broken and the drum is catching on the surrounding plastic outer drum.
Mar 15, 2016 | Kenmore Elite 45986 Front Load Washer
Machine will not spin out water,does this machine have a belt driven drum or is it direct drive? found under unit what was thought to be rubber material on floor
depending on the model you have it can be either or.
if you can lean the machine back and take a llok under neath you might be able to see the motor and the drain pump might be attached to the front of the motor. look just behind the motor and you should see a black rubber piece with two white plastic pieces this is a drive coupler and if it is broken then you need to replace it
Jan 31, 2010 | Washing Machines
Leaking water at the bottom and making load noise
From the description of your problem, there are two possibilities.
One, water valve will have to be replaced.
Second, the area of the leak indicates a leaking drain pump.
Hope this helps.
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
I am getting a message on the washer saying "HF" what those this mean?
google " duetservicemanual.pdf" I see an error code "FH", but nothing listed as "HF".
Nov 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
CR1610E noisy Drum
at the bottom of the drum there is a little white piece of plastic that locks the drum in place.. make sure that that piece is not rubbing against the drum
Jun 11, 2009 | Riso RZ220 Duplicator
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Activision Guitar Hero III for Nintendo Wii Logo
203 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
