Question about Saitek Cyborg 3D Gold Joystick
Saitek 3D Gold manual
I do not have a manual for my joy stick and I need to know what all the buttons are used for. Is thier any way that I can buy or get a manal for this joy stick ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
The buttons do what you want them to do. The stick is programmable. Most games allow you to map the joystick controls the way you want. With others, you can map them with the Saitek software. Download the drivers and software at:
http://www.saitek.com/uk/down/drivers.php
Posted on Jul 19, 2010
  • 67 Answers
Try this site:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Jan 26, 2009
Need wireind diagram for logitech wingman joystick to usb for my hp dv6 laptop
Wouldn't it be easier to buy a specific analog or digital gameport-to-USB adapter? Most of them are under $10 now, even the name brands.
Feb 12, 2015 | Saitek ST290 Joystick
Tip
Installation, and testing the Logitech Extreme 3D Pro Joystick
The joy stick comes with a CD. Put the CD on the tray, and let the computer runs the software. On the CD there are driver for the joy stick itself, and driver for the USB . click on install joystick, after that, click on install the USB drive. that is it. Then a test screen will appear and asks you to check your joystick movements and buttons .push on the buttons,on the joystick, and you will see that they turn red on the computer screen each time you push a button, meaning your computer reads the commands from the joystick, You are set.
If you do not have the CD, then go to the Logitech site. and go to support, and from there you can download the drivers for the joystick.
on May 04, 2014 | Logitech Extreme 3D Pro Joystick
Microsoft Combat Simulator Doesn't work with joy stick satik 290 pro. nothing works. it worked on xp. doesn't work on vista home.
You need the drivers from Saitek.com.
After selecting download > software, use the "Choose your Product Type) box. Select Joystick and you will find yours listed.
You need to know if you're using Vista or Vista64.
Install them, then plug your stick in. Should then work.
Aug 11, 2010 | Saitek ST290 Joystick
The throttle is stuck open on my Saitek 3D Pro, how can I fix it? Multiple calibrations thru FSX have proved unsuccesfull. It's hard to finish a landing with it open
You need to completely remove the calibration you have done. uninstall the driver, reboot and then connect stick back up. Follow on-screen prompts for the driver disk and reinstall. Check there are no conflicts in the sticks own software once installed, then calibrate it.
If still no go, then the stick is faulty.
Apr 23, 2010 | Saitek (PS28) Joystick, Throttle
What adaptor must have for my computer? the joystik have not usb.
I too have this exact same joystick so when I tried to plug it into my new pc (that I built 2 yrs ago as of Feb.14,11) I had to use a: 15-pin to USB adapter with chord.
I got it from eBay.ca in the $5-$10 range shipped to me from Chnia.
It's called the: Super Joy Box 7 USB Gameport Adatper
They are still available from eBay.ca & eBay.com as of Dec.06,10 (the time of writing this posting).
For me it wokrs, but only 1/2 - as in:
- the fire button + 3 other buttons - work fine
- the HAT switch (4-way) - refuses to work
- the full range of the joysticks motions are reduced (on the right side)
Because of these limitations I had to learn to used the keyboard buttons to fly planes & choppers in the pc game - GTA:SA.
I plan to buy the pc game GTA4 as soon as it goes down in price of it's current $20 & buy a...
Saitek Cuborg Graphite Joystick PS21 that is newer and uses a USB connection.
Feb 08, 2010 | Saitek Cyborg 2000 Joystick
I need to fix the ENTER button.. I've removed the case screws anf do not want to damage the seam with a screw driver. Is thier some other catch or tang I'm missing.....THNX...Patrick
To fix this problem with the malfunctioning " Joy Stick", and or selection or enter button, you must seperate the Remotes halves. There are no springs or other parts that will come flying out when the halves are split. Do Not use a screw driver to separate the seams the best tool is a tool used by manicurist on cuticles or make your own. Squeeze the bottom half while moving along the seam. Once you have two of the plastic catches released, the others will come apart. Then remove the three philips screws that will allow you to remove the board and attached LCD screen. The LCD screen is attached with a ribbon cable. To remove this cable, first back off the cable pressure locks! What looks like the end of the cable is only a pressure lock and stays with the main board. Do Not get in a hurry with this ribbon cable! Use a magnifying glass to have a close look! Turn the board over and remove the " button boot", this will allow access to the joy stick. The joy stick button is a friction fit and can be removed with equal upward pressure. Now you are at , what is a five way switch. Study the switch with your magnifying glass and a good light, you will see how the metal bracket holds the switch together. Bend the catches back on only one side of the bracket. This will allow you to remove the joy stick and see the five small concave metal discs. These discs are tempered to make contact and return to there concave shape. The center disc on mine was not concave, but near flat. These small parts will want to get lost!! Move slowly! I removed the middle disc and used a gold plated RCA plug that was rounded just enough to match the concave design of the disc. A few light taps and the disc conformed to operational shape. Putting the small disc back into the switch was testy. Reassemble the unit slowly, pay attention to the RF antenna, you do not want to break the solder connections. Clean the LCD and be sure you have the ribbon cable seated all the way into it's clip.
My RC-8000 now works and fixing this pesky switch cleared up a few other odd things going on in my 5803.
Patrick J Horan
Oct 02, 2009 | Denon RC-8000 LCD Touchscreen Remote...
Saitek AV8R-01 Joystick - How to install?
No download disk is required. Your PC will automatically 'find' the joystick after it has been plugged into a USB port.
You can just about play any flight sim with this joystick, jat, prop plane or helicopter. The buttons do what ever you program them to do through your game's control settings.
Mar 19, 2009 | Saitek Aviator AV8R Joystick
Unplugged my Extreme 3d Pro/When plugged back in, can't calibrate
have you choosen to use the stick in the game controlls options in your games? if not you just choose using joy-stick and customize the buttons and Y-X-axis to what you preffer
Dec 31, 2008 | Logitech EXTREME 3D PRO TWIST HANDLE...
Saitek Cyborg 3D Gold Joystick Logo
1,332 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
