Problem with Panasonic PV-GS39 Mini DV Digital Camcorder
The camera works fine but when I put a tape in it it tells me to hit the rest button and I dod and it will come on for about 5 sec. the tell me to hit the reset button again. How do I fix theis problem. Thanks Ronnie G
363 people viewed this problem
This solution has been voted best by the Fixya Commnunity
...and try this first...:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
NV-MD9000 , NV-GS11, NV-GS60 and all other camcorders have problem of "Push the reset button"(flashed on LCD after 2-3 months . This problem is due to some company defect in soldering in Main board.
Get the cam checked by a good electronics tech guy instead of taking to panasonic service centre coz in service centre they will simply ask you to change the board.
all the best my friend
sreejith
I have a problem with my Panasonic dv53. It keeps causing the tapes unwind out of the minidv cassette...
camcorder will not load the tape, the cassette compartment mechanism will not close and just ejects the tape.Compartment...
My panasonic nv-ds29b worked fine. Then i took it on holiday and now i cant view what i recoreded. The lcd screen is on...
During playback my video images often break up and then will drop out altogether. There is no hint that this is...
Hi, My camcorder has thick grey horizontal lines across the screen when i record and whenit plays back. i bought a head...
Ronnie Green I have sent it off to be fix. Thanks and I will let you know if that is what is wrong with it.
Thanks
Ronnie Green
Jul 18, 2007
Guest I try to record and it starts to for half a second and then the screen turns blue and says hit reset, so i hit it and nothing happens it just wants me to reset again. Also after this i look at my tape and the film is partially out. Its not the tape cause i used many tapes trying to fix my problem.
HELP!!!
May 13, 2009
