Question about Keurig Platinum B70 Coffee Maker
Drain keurig b79 for shipping
Where is the drain plug for keurig b79
Need address where to ship Keurig to have repaired
call 1-866-901-2739 first, customer service will give you an authorization to return number. If you dont get a number they will ship it back to you. Keurig Incorporated 55 Walkers Brook Drive Reading, MA 01867
Jan 21, 2015 | Cafe Cup TM 4 Pack For use with Keurig...
Keurig b79 platinum plus leaks water all over the counter. I believe it's from the reservoir. How do I fix it?
Time to replace. Theres no room for profit if you replace the reservoir.
A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
Nov 22, 2014 | Keurig Platinum Plus B79 Platinum Coffee...
Keurig blue light flashes display shows prime
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. A common Keurig problem.
Jun 30, 2014 | Keurig B100 Coffee Maker
Keurig reads prime
Apr 16, 2014 | Keurig B60 Coffee Maker
My keurig will not drain watter from watter reservoir when I press the bruew botton once it is ready thus, it will not brew. Like it is plugged? help
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 09, 2011 | Microwave Ovens
In the last couple of days our Keurig has been giving us lots of grinds. One entire cup was fllled with them while others have them floating. We use the K-cups from Keurig shipped to us. The coffee...
Hi,The bottom needle is plugged so the coffee is running back out over the top instead of going through the bottom needle...use a paper clip to open it up...
heatman101
Aug 06, 2011 | Keurig Elite B40 Coffee Maker
Draining the keurig
It can not be drained, ever!
Dec 26, 2008 | Keurig B100 Coffee Maker
Can I hook up a water supply to a Keurig B100 brewer?
The B100 is a pour over unit and the drain is just that.. a drain directly connected to the tank... In order to have plumb feature the machine would need a fill solenoid attached to a float.switch through a circut board of sorts...Hope this helps
Robb
Nov 25, 2008 | Keurig B100 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
57 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
