Question about Gaggenau Ovens
I have an EB 876-6 oven - door is locked and cannot open
New house, new oven door is locked since last night..must have pushed the wrong button. Thank you
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
SOURCE: What is the reset button for GE Profile JTP18?
For me the solution was in the temperature sensor. The Locked light kept flashing and the door locking mechanism kept cycling when the door was shut or if I just held the oven light switch in the closed door position. After replacing the control panel I still had the same problem. Next I turned off the breaker and then took off the wire covers on the back of the oven and disconnected the temperature sensor. I then checked the continuity of the sensor which was fine. With the sensor still unplugged, I turned the breaker back on and the panel said locked but the locking mechanism was not cycling. With power still on to the oven I connected the temperature sensor. It worked. All I had to do was press the clear button on the touch panel and everything was fine. I turned the breaker back off and reassembled the oven. Hope this helps.
Posted on Dec 12, 2008
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
mrbobfixit
  • 259 Answers
SOURCE: How do we unlock the oven door! Accidentally
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Posted on Aug 18, 2010
How do I get the door open on my oven?
Most newer ovens have a lock on them, and you probably haven't noticed it. look for a lock button. It will probably be electronic, not a mechanical button. Not sure what brand you have or how old it is.
Apr 25, 2015 | Ovens
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
Power outageoven says stop the little button seems jammed wont push in any way around this?
i have the same problem. the oven was installed in my new house before i moved in, the display just says stop an the button doesnt click or anything? did you manage to find out what was wrong?
thank you
Jul 01, 2010 | Whirlpool AKZ159IX Oven
New oven won't work and can't set time, display keeps blinking
Hey--  You've spent a bunch of time on this already, so let's figure it out. The first step is to check power connections. L1, L2 , Neutral for proper location and tight connections. Should have 120v and 220v checked at bus block. If these check out, then this new unit should be under warranty and qualify for service. Not unheard of bad board or loose wire on a new unit. Let a tech sort it out on site. Let me know if this info helps- have more if needed-  Thanks-  Ed
Mar 15, 2010 | Whirlpool Ovens
F9 is appearing in the clock window
HI. This will code is indicating that the oven door lock mechanism is experiencing difficulties. Check the wiring to door lock switch (the wire harness may be connected wrong, or loose). Check for stuck lock switch, as well.If the wiring is not loose, or connected improperly, this will lead to a failed door lock mech. it will require you, ro your service tech to replace it, in this case.
F-9 Oven door lock failure
Dec 07, 2009 | Whirlpool Ovens
Oven will not unlock.
There is a little motor at the back of the oven that rotates a shaft that runs all the way to the front of the oven to lock the door. The motor may be shot:
http://www.partselect.com/PartDetail.aspx?Inventory=2342830&SourceCode=4
89 318095949 Motor, latch assy, w/brkt & switch
Apr 04, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Oven locked up
What breaker did you shut off? House breaker? Or the ovens internal breaker? My drop in has a set of push button breakers under the oven behind a fold down door. The fold down door is in place of a regular ovens pull out drawer. Check in there if you have one. The light are more than likely a warning somethings wrong. If this was just installed check to make sure it was grounded properly. Also check to make sure the AMP rating of the stove and the one in the house breaker box match up. The house one can be higher but not the other way around. Hope that helps.
Jan 04, 2009 | Ovens
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
