Question about Westinghouse WST1810 Canister Vacuum
How to you empty it out - Westinghouse WST1810 Canister Vacuum
Help! i need to empty the dust compartment on the steam cleaner /vac and i cant find instructions
You need to ask again but give the MAKE and MODEL number of the machine, so we can help you.
Sep 14, 2014 | Vacuums
How do I empty the hvc-22
If you are meaning the DC24, like your post seems to be tied to, the manual can be found here:
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC24_Manual.pdf and the pictures for removing the canister and triggering the lower empty-hatch are on page 3 under 'Clear Bin Emptying'.
Good Luck!
Jul 13, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 | Vacuums
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Same problem removing the easy empty cup..
The dark gray plastic slide is separate from the Easy Empty Cup. Just slide the release tab all the way to open position, and then pull the Easy Empty Cup straight up. With a little effort, the cup will dislodge from the dark gray plastic platter.
Sep 08, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Why is my swiffer vacuum working up to full power and then it needs emptied and then it loses power after I empty it?
it can't be that it loses power, it just gets loud when it's full, not so loud when it's empty?
Sep 07, 2009 | Vacuums
How do I empty this dust buster?
Most of this type have a bag filter that you take out, it is just insie the front part that you take off , then you can empty and clean it.
Dec 23, 2007 | Black & Decker CK1300 Dustbuster Wet/Dry...
HOW TO EMPTY
One of 2 ways, some you just take the top off, it will have a paper bag that you can toss and put in a clean and empty one. The other is the bottom is actually a bucket that unhooks so you can empty it. Hope this helps.
Nov 05, 2007 | Cana-Vac 511Q Central System Vacuum
Westinghouse WST1810 Canister Vacuum Logo
23 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
