Question about Lenovo G580 Laptop
Numlock at start up - Lenovo G580 Laptop
My K120 Logitech is not working on the numbers side and the accents don't either
Do you have numlock disabled? Try checking the indicator on the keyboard for numlock. Hit the numlock button and see if they start working again.
Oct 10, 2013 | Logitech Computers & Internet
Tip
Turn off NumLock
Numlock is on but I can not find it on my keyboard, if you are facing this problem here is what you can do
  1. Go to Start
  2. Then All Program
  3. Accessories
  4. Accessibilities / Ease of Access ( Depending on what type of Windows)
  5. On- Screen- Keyboard
  6. When in this look for Numlock and press it, it will turn off now
on Oct 27, 2010 | Computers & Internet
Tip
Annoyed that your Num Lock key isn't on when you start your PC?
Here's a quick tip to ensure your numlock key stays "ON" by default when the computer starts.
1. log off your PC to the Ctrl-Alt-Del screen
2. Turn on the NumLock key
3. Hit Ctrl-Alt-Del (like you are about to log on)
4. Don't log on, hit the "shut down" button to turn off your PC
This saves the numlock key in the "ON" position by default when the PC starts.
on May 20, 2010 | Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
How to activate NumLock as a default? My job requires that I work with numbers the majority of the time so I need to keep the NumLock active. However, each time I log off, the NumLock automatically...
A simple reg edit will do this
For current user:
  1. Start Regedit
  2. HKEY_CURRENT_USER\Control Panel\Keyboard\InitialKeyboardIndicators
  3. Change the value from 0 to 2
For all users:
  1. Start Regedit
  2. HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyboardIndicators
Jul 09, 2010 | Dell SK8110 Keyboard
When i typed my password it dosent enter to the setup.
his causes the customers to have troubles logging into Windows if they wont notice the numlock status.
Here's what you need to do.
1. Start the system up
2. When on the logon screen, turn the numlock OFF(FN+numlock). Do not login yet, instead restart the computer via the power button.
*The numlock should be off by the next reboot.
Mar 03, 2010 | Acer Aspire 5520-5908 Notebook
Maxdata 6000 I numlock disabled
in start menue go to all programs> accessories>accessability
and open the on screen keyboard.
there the numlock button will be shown highlighted. just single click on the numlock button.
dont forget to vote.
Sep 16, 2009 | Computers & Internet
Why does my numLock have to be pressed down everytime I start up my pc?
Whether numlock is on or off when you boot is based on a setting in your bios. When you first start the computer you should get a prompt indicating what key or keys to press to enter 'setup'. Once you are in there, simply go through the options until you find the option for numlock and set it so it gives you the desired behavior.
Apr 22, 2009 | Logitech Computers & Internet
How do I set numlock to be on at start up?
Hi there
you need to restart the PC and enter the bios, this is usually F2 on start-up, have a look through the bios and set the numlock to on at start-up.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Toshiba Satellite P205-S7476 Notebook
NUM Lock
I solved this on a toughbook. The numlock was activating while windows started even with the regkey set to have it off.
(http://support.microsoft.com/kb/154529/en-us)
All I had to do was restarting the PC waiting for windows to activate the numlock again during the shutdown process and then hitting the numlock once before windows was done.
Next time the Toughbook started the Numlock kept off!
Aug 12, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Lenovo G580 Laptop Logo
113 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
