Question about Tappan Ovens
Oven will not turn on.
Tappan wallmount oven.
mfg date 1961, EOWV-510, mod EOV-510, pt# 191T100F02
I don't think this oven was ever used-looks new inside and out.
Analog Clock system control. Looking at the mechinism it seems to have a main clock with an alarm(start) hand, and a bake time dial with a manual position. Knobs are very hard to turn. There is an actuator on the back of clock that should close a switch, in auto start from the clock or from the manual position. When I put the bake time switch in manual it seems to lock the actuator in position away from switch. I have used a screw driver to close the switch, and the oven works.
ANY fixes or available parts out there for this unit
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
Powerman
  • 68 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Posted on Feb 07, 2008
  • 1462 Answers
SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
Posted on Jul 24, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
Seal on Tappan wall oven came off, what to do?
Hey friend, I appreciate your post!
I understand that seal on your Tappan wall oven has come off. In order to provide you additional information regarding the seal I would need your model number and serial number. You can locate the serial tag (which has your model number listed) on the front of the oven on the left side. With that information I could provide you additional assistance. I look forward to your response. -Matt
Aug 03, 2014 | Tappan Ovens
The oven won't turn on. Any suggestions?
You may want to check the video and site I have for you.
My oven won turn on
May 15, 2014 | Tappan Ovens
Where can I find bottom burner oven valve
Here is where you can find most parts copy and paste the link below into your web browser to look.
http://www.partselect.com/ModelFrames.aspx?ModelID=917028&ModelNum=fgf337awa&mfgModelNum=&ManufactureID=4&Selected=6HODOMXW&Position=2&mfg=Frigidaire&Type=Appliance&Mark=2
Apr 07, 2012 | Frigidaire Ovens
I have a designer series self cleaning oven and I have lost the instruction manual of how to clean the oven.
Hello janicejoh679, there is no manual for YOU to clean the oven, it's a self cleaning oven. Okay, please pardon my loose sense of humor.
A friend of mine was able to get a free replacement instruction manual from Tappan off of their website several weeks ago, I think she typed, " tappan", in the google search bar to find their official website.
I hope the info helps you,
Jan 09, 2011 | Tappan 30IN ELEC IGNa Oven
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Sep 08, 2009 | Tappan Ovens
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Convertion to LP
Generally, there is a kit to do this. Contact the manufacturer.
Dec 28, 2007 | Ovens
Ovens Logo
55 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
