Question about SanDisk Sansa e140 MP3 Player
Don't know how to delete files
I have a sansa e140 i have some music on there but i dont know how to delete these items can u tell me how.
    Problem Solver:
  • 7 Answers
1. Open the file browser on your computer and navigate through the folders to the drive assigned to your Sansa MP3 Player. 2. Select the music files that you would like to delete by clicking once on the file, if you want to delete more than one file hold your control(ctrl) key down as you click each file. When you have clicked on all the files you want deleted release holding down the control key. Then push the delete key. The files will be deleted. You also can use Rhapsody and other software to save or delete files directly to your player.
Posted on Jul 15, 2007
SOURCE:
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
I have aquired an e140 1GB MP3 and need a manual.
http://www.sandisk.com/assets/File/pdf/guides/sansa-e100-userguide.pdf
I believe this should be the manual that your looking for. You may also want to try hooking the MP3 player up to your computer via the usb cable. After doing so, if nothing automatically comes up, you should be able to open the players drive via the my computer option. A lot of times a copy of the manual and the operating software can be found here.
Jul 27, 2009 | SanDisk Audio Players & Recorders
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
Hey can you tell me how to fi this problem my san disk e140 is telling me not enough memory cnnect to the pc delete 4m of songs for sansa system.i have tried everything it told me and it still do not work...
to solve the problem do the following things:
- download the firmware (http://www.sandisk.com/Retail/Default.aspx?CatID=1295)
- run firmware - SW
- FirmwareDownloader shows "Detecting"
- put oft the battery of the e140
- hold down the Power Button
- Connect the e140 to the PC
- FirmwareDownloader shows "Recovery mode ready"
- press start-Button
--> e140 works
Sep 28, 2008 | SanDisk Sansa e140 MP3 Player
Sansa e140 error
There is a Problem with the flash memory on the Mp3 player I would request u too replace it
Aug 03, 2008 | SanDisk Sansa e140 MP3 Player
How do i delete music off my sansa mp3 player?
Source: http://www.ehow.com/how_2023687_delete-files-sansa.html
Step 1Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. Step 2Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory. Step 3Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. Step 4Click on single items or click and lasso multiple files. Step 5Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. Step 6Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs. Tips & Warnings
  • Optionally, you can left-click on a file and drag the file icon to the Recycle Bin. Either way, you can delete music that you don’t want from your Sansa MP3 player.
  • Unlike other documents and files, once the music file hits the Recycle Bin, it’s gone. Make sure that you are deleting the correct file.
For more help: http://www.supportrix.com/
Jul 30, 2008 | Audio Players & Recorders
Sansa e200 music
Well formatting IS deleting all the files on your sandisk. I figured that out the first day i had it. So if you're formatting when all your songs are on there, then that's your problem. If not, then i dont know what to tell you.
Apr 09, 2008 | SanDisk Sansa e200 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
No change is recognized in the playlist
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Nov 15, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa e140 MP3 Player Logo
270 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
