Question about LG Televison & Video
Lg rh387h dvd cant play back due to navigation error
SOURCE: Need to play region 1 DVD in region 2
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail nikraj@telkomsa.net
Posted on Jul 25, 2008
guru_dev
  • 315 Answers
SOURCE: DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Or
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: cannot playback dvd-r on lg rh397d after recording
When you burn a DVD, it is ONLY playable in the RH397D.
Buggy menus - and no way to flash the firmware.
Terribly designed remote.
HDD never seems to spin down, no matter how long it sits.
Doesn't play XVid.
I was a bit disappointed with this product. It does do, what is listed on the box, and one can't be too disappointed with that.
Posted on Sep 29, 2009
SOURCE: is there any way i
1. press home on remote
2. scroll to setup options
3. scroll to lock (DO NOT SCROLL SIDEWAYS)
4. press zero seven times (message appears)
5. press enter
dvd player now region free
Posted on Nov 19, 2009
alpug
  • 1961 Answers
SOURCE: on my LG RH387H dvd hard drive the dvd tray won't
mechanical timing and allignment is the prtoblem of your dvd player...you need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand..make sure that the cd loader reaches the limit switch before it closes..
Posted on May 18, 2010
When finish rec from HD to DVD it wont finalize it , Keep coming up Navigational Error , even when playing normal DVD
you can not record from HD to DVD because it has a lot of difference in resolution .....for HD you need blueray disc not dvd.....
Sep 28, 2015 | LG Rht599h 500Gb Hdd Dvd Recorder With...
My lg rh387h dvd wont go past hello screen
It shows that the memory IC of this set is corrupted,this is pre-programmed IC that can be replaced with the same programmed IC to solve the problem.
Feb 04, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I recorded video from my Sony Handycam to the RH387H HDD and then wrote the video onto a DVD-R disc using the XP setting (instead of SP, LP.....). The disc can only playback now on the LG387H, but cannot...
make sure the disk is finalised after recording, if this does not help then the bit-rate it uses for xp may not be compatable with other dvd players, in which case stick to sp,lp or dual-layer sp is best if ou can.
Jan 25, 2011 | LG RH1999H DVD Recorder/HDD Recorder
On my LG RH387H dvd hard drive the dvd tray won't open fully and now it has started to open on power up and when i try to close it it keeps opening even though there is no dvd inside
May 18, 2010 | Televison & Video
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
Cannot playback dvd-r on lg rh397d after recording from hdd. message is 'cannot playback due to navigation error' please help
Doesn't play XVid.
Sep 29, 2009 | Televison & Video
Is there any way i can unlock a lg rh387h dvd recorder to be region free?
5. press enter
Jul 05, 2008 | Televison & Video
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Televison & Video Logo
59 people viewed this question
Computer Repairing
Computer Repairing
