Question about Panasonic TH Televison & Video
CIRCUIT BREAKER WENT OFF NOW TV WONT COME BACK ON
Put power back on still tv will not come back on
SOURCE: Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Posted on Oct 31, 2008
  • 8457 Answers
SOURCE: clicks wont come on like circuit breaker going on
Ur power board is dead,know how to solders?Check the power board for Capacitors puff up or burst open replaced these capacitors.Or buy refurbish power board on Shopjimmy.com,Ebay.com.
Posted on Jan 16, 2010
cschindle725
  • 67 Answers
SOURCE: TV was on. Now it is off and will not turn back
more than likely blew a fuse on the power supply take the back off and check the fuses with voltmeter
Posted on May 20, 2010
Testimonial: "Thank you. I last took off the back of a TV 30 years ago when I got out of Electronics school-now I do another line of work-and the back through which the line cord went slid off the top of the TV sliced the tube in half and knocked me about ten feet onto a couch. I have never opened the back of a TV since then. But, since it is my baby, I will give it a shot. I was hoping they would just have a push button circuit breaker like the old TVs. Thank you."
  • 8457 Answers
SOURCE: My lcd Tv Acer AT3201W made a loud pop which
The tv power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jul 03, 2010
  • 144 Answers
SOURCE: power went off and came back on last Friday and
Have you got a stand by light on, or is tv dead totally.I would Check plug fuse if dead, My suspect would be power supply capacitors drying out (had this fault recently with friends tv) this caused tv to be working sometimes but eventually stuck on standby. Capacitors are cheap but not a job for the novice.
You could ask local tv shop for estimate
pete
Posted on Nov 08, 2010
Why wont my insignia tv NS-D260A13 turn on after a storm?
Could very well have been shocked by lightning. If so, it is probably dead. To check, try the wall socket with a light to see if there is power there. Check the power line to the TV to see it is in good condition. Look on the back of TV for a fuse or circuit breaker (and if you have an extension cord with a circuit breaker). Use both TV mounted Power On button and the remote. If all this fails and the TV is expensive or in warranty, you have to fix or trash it.
May 20, 2017 | Insignia Televison & Video
The power went off and wen it came back on the tv wont turn back on
If your power outage wad caused by a surge your tv may have died. Check fusebox for tripped circuit breaker also check tv wall plug fuse in case that has blown. It might be that the tv internal fuse has blown, you should disconnect the tvv from the electricity supply if you intend opening the rear of the set to check this.
If they are all okay the set probably needs the services of a trained technician
Good Luck
Jun 08, 2015 | Televison & Video
Why wont my Tv turn back on after the electricity went off?
Did you have your television plugged into an outlet with a surge protector? Does it do anything when trying to turn it on? Might have fried it when power came back on or when elec. went off.
Feb 05, 2015 | Emerson Televison & Video
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
Tv went off wont turn back on
Make sure you've unplugged all external connections to unit. Try unplugging TV from power source for no less than 10 minutes. Plug in again, and see if it comes on by depressing the unit's ON/OFF switch (NOT via remote). If not, then try something in receptacle that you're plugging into. If no power, then check your circuit breaker. If still no power, then may require service.
Jan 14, 2013 | Televison & Video
I have a ticking noise when i try to turn on the tv..
Try putting on the back piece. Some of these TVs have a circuit protection system that will not deactivate with the back open. (It is like an old circuit breaker with the fuse out.)
I hope this helps.
Jun 03, 2010 | Philips 50PL9126D/37B 50" DLP TV
Can't get power on tv
They do not use circuit breakers only fuses. The fuse is on the power supply board where the cable from the AC box plugs connects to the board. If the fuse doesnt fix it the power supply board will probably have to be replaced, if not one of the other boards may also be damaged.
May 26, 2009 | V, Inc. Vizio P50HD Plasma Television
Is the LED light on? If not then the Power supply may be bad. Try to unplug the TV and then plug back in. There is a fuse near the AC input. Check the fuse If the fuse is OK then the Power supply has gone bad.
Apr 01, 2009 | V, Inc. Vizio P50HD Plasma Television
Tv wont come on off and on light wont light up
Does the outlet still work?
also, for safety sake, reset your circuit breaker.
let me know...
Mastersage...........................
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Samsung TV
If your model has a reset button it will alway be on the back,
usually near the power, sometimes near the lamp if it is dlp.
plainly marked.
Or just unplug it , press power on . then plug it back in.
Jan 27, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
