Question about HP LaserJet 3200 All-In-One Printer
HP LJ 3200 - Pulls ALL pages through at once
When I try to fax, scan, or copy, the machine pulls all the pages at one time. This is okay for copying, but if I try to send a fax, I have to attempt to feed each page separately but fast enough that it sends in the same fax. Can you tell me how to fix it?
Thanx so much.
  • wtittle Jan 30, 2009
    That worked! Thank You!!!
  • 62 Answers
Your problem seems to be the feed and separation pad/roller.
Open up the cover where you set the paper at and there you should see at least one pad and one roller. Clean them up with a wet rug. try to clean it up as much as you can. It the problem fixes it for at least a while it means is time for you to get new ones (pad and roller)
Posted on Jan 27, 2009
  • Carlos Perez
    Carlos Perez Jan 30, 2009
    glad i could help, now go get yourself new separation-feed pad-roller...
HP 1050 Fax--replaced Ink Jet Cart. and now it will not receive but will send okay!
Please do a copy of any page, if you have a printed copy the ink cartridge is OK and maybe you only have automatic answer turned off.
Mar 02, 2011 | HP 1050 Plain Paper Inkjet Fax
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Adf pulls 2- or more pages in feeder.
open the ADF and clean the rollers and wooden cork pad and unplug the machine and press and hold the ON button for 1 min and release the button and plug it bak and it should resolve ur issue........
Regards raj_p5983
Jan 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Problems with copying
Pull front of fax machine open
look down
clean the little glass ****.
Jul 19, 2008 | HP 1220xi Plain Paper Inkjet Fax
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Fax film pulls through with copies
timing is usually associated with a motor, try and see if the motor can be dismanteld, clean with alcohol and put oil on finger to lube inside.
If not then motor needs to be changed.
Feb 11, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
HP LaserJet 3200 All-In-One Printer Logo
192 people viewed this question
Ben Johnson
