Reset service mode on drayton lp241si - Office Equipment & Supplies
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
How to set up the perfect focus for shooting jewelry in manual mode?
I would suggest setting your white balance first by putting the camera on "P" mode, then pointing the camera at two or three pieces of white copy paper stacked on top of each other in the same spot where you will be taking the photos. Press the "Func/Set" button and then "Disp" to set the white balance.
Now put the camera in Macro mode by pressing the jog dial towards the "flower" icon and pressing "Func/Set" again.
If you can, try using a tripod to hold the camera as still as possible and then try shooting your jewelry.
Hope this helps!
Thomas Drayton
Owner Darntoothysam.com
Affordable Digital Camera Repair
Aug 01, 2011 | Canon PowerShot G9 Digital Camera
Drayton digistat 2 thernostat manual an elderly neighbour can not set it and has lost manual
Go line to Drayton site and download a manual for him and follow it to the T. It to hard setit out. Ken'Repair
Jan 22, 2011 | Heating & Cooling
Where can I download a user manual for a British gas WR1 thermostat? I've searched the net with no joy so far.
From what I've found - these are re-badged Drayton stats. I'm not familiar with the "BG" brand or the Drayton for that matter as I'm in the US - but they are apparently enjoy some popularity in the UK.
I found this on the Drayton stats. The BG WR1 is either the Drayton RF1, RF2 or RF3 (depending on configuration). All of them are pictured towards the bottom of the link provided previously. Links for each model's Installation, Operation and Quick Guide instruction manuals are next to each picture.
I hope this helps. Please rate my reply - thanks.
Jan 10, 2011 | Heating & Cooling
I need the user instructions for the Drayton Digistat RF3 wireless system
Try here:
http://www.draytoncontrols.co.uk/supportingdocuments.aspx?id=1504#
Note that if the manual is not online the customer service contact info is so you can email them to have the manual sent to you.
Dec 17, 2009 | Garden
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
42 people viewed this question
k24674
jasbo
jasbo
