Question about Freezers
Kenmore Freezer Model 253.28432800
Control Panel goes blank. Unplug and plug back in and control panel comes back on. Should I worry? Unit is 4 1/2 years old.
watugot
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
tzweeb
  • 318 Answers
SOURCE: my freezer is not cold enough to keep food frozen...
the "e" usually means it has an error. it could be a bad temperature thermistor or a bad control board. the most likely is the board.
i hope you are less then 1 year old as the board can be quite pricey, about 150 bucks.
you could try to unplug the unit for a few minutes and then plug back in and see if the code goes away and returns to the cooling mode.
Posted on Dec 29, 2008
Bat1956
  • 585 Answers
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Posted on Jun 28, 2009
  • 86 Answers
SOURCE: I have a 7 year old Kenmore Upright
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Posted on Jul 14, 2009
SOURCE: My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
Posted on Sep 29, 2010
Frigidaire Upright freezer the temp indicator light will go blank and the freezer will stop cooling. You can unplug unit wait a bit and plug back in and it will will work for a while
I would guess the control panel is failing, but due to the cost of the part have a technician come out and confirm that is the issue. You can also go to www.partsdirect.com and email the forum
Sep 21, 2016 | Frigidaire Freezers
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Had a power outage for a few seconds, the control panel is not working on my refrigerator, it reads er lf.
This error means some thing is wrong with the fan to the ice maker. It might also be a bad control board. If it is still under warranty get he board replaced. Kenmore has had some problems with these particular boards. You make be able to reset board by unplugging unit for a while and plugging it back in. Hope this helps
Jan 03, 2014 | Kenmore 31 cu. ft. French-Door Grab-N-Go...
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Mar 20, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
We have a Kenmore freezer chest...lights come on but doesnt freeze model#253.9135381 serial #s409256481
first,have you defrosted the frzr recently?they must be defrosted manually. take the 2 screws holding the side panel on and see if you hear the compressor humming/running. if you do. then the problem is in the sealed syetem. they should to come w/a 5yr. parts & labor warrenty but it looks like your frzr was build in the 1990's...
tip: if you think it's your cold control.you could unplug unit and use a wire,jump out the cold control.
Jul 16, 2009 | Freezers
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My freezer is not cold enough to keep food frozen...
Dec 29, 2008 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezers Logo
264 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
