Question about Samsung SGH-G600 Cellular Phone
G600 problem can some one help me my g600 samsung keeps switching off every time i put it on it comes on for 5 secounds and then switchs off an carries on doin that untill i take the battrie out ... i have tryed a new battrie but thats not the promblem please help
  • baybii_angel Jan 29, 2009
    my phone does the same thing when i try and play music
    they are all in the right format for the phone, but whenever i try and change the song, it just switches right off.
    full battery and everything, but hey ho
    this solution seems good :-)
    i shall try it xx
  • Anonymous Feb 03, 2009
    Everything is set to default settings. screen delays when navigating and if i have to turn the phone off and on it will show funclub then restart to teh sgh g600 screen and power off and right back on.
    does this for over half an hour. . . till i get tired and power it off. i let it run overnight like this and at some point it turns on. . .
  • 50 Answers
Is the phone charged fully, if so strip the phone and leave it separtred for 15 mins and put it 2 gether a again
Posted on Jan 25, 2009
Phone will not switch on battery fully charged. This problem started when I took battery and sim out of phone to test another phone. Did not switch the G600 phone off before removing battery.
Usually these problems only occur when the phone is substandard. regardless of you switching the phone off or not this is not a prerequisite to not come on. If you still have warranty on it return it.
Most times when this problem arises in phones it is because the phone was a refurbished one. Refurbished phones are phones which are made up of the scraps from other spoilt similar devices. It usually is a waste to try and fix these devices because you will end up spending more than the cost of replacing the device.
Hope this solution has been helpful?
Apr 11, 2011 | Samsung SGH-G600 Cellular Phone
Samsung g600 mobile phone keeps freezing up
make a factory set on your phone. to do this, please follow the steps 1.  back up your files 2.  switch off your phone 3.  remove your battery , sim and memory card 4.  reinsert battery and switch on 5.  on your keypad type the code *2767*3855# 6.  after a successful factory set, reinsert your battery, sim and memory card.  7.  switch on and reconfigure to your settings..
take care..
Mar 10, 2010 | Samsung Cell Phones
Phone keeps switching itself off
Friend the power switch is shorted ask mobile technicians to solve the problem
Apr 09, 2009 | Samsung SGH-G600 Cellular Phone
Phone lock needs unlocking - samsung g600
i have a samsung G600 and it is from uk and when i out an indian sim it asks for network lock
Jan 19, 2009 | Samsung SGH-G600 Cellular Phone
Show my number!
.here is the definitive fix for the "show my number syndrome" is a known fault with the Samsung G600 software. What you need to do is, borrow another sim card for the provider you are with and put it in the handset, run through the welcome sequence, save and switch off.
Then put your own sim card into the handset and repeat the welcome procedure, the show my number will now be set on default..
Ths is the only fix at present until Samsung release a newer software with the problem resolved.hope this helps pls appreciate by rating this as fixyaaa thanks and Godbless
Jan 16, 2009 | Samsung SGH-G600 Cellular Phone
How to reset Samsung SGH-G600
you can reset your phone by hard reset method, that is, switch off your mobile and remove the batteries and remain it for one hour and then put the battery inside and switch it on , your phone will be rest
Jan 10, 2009 | Samsung SGH-G600 Cellular Phone
Can i unlock my samsung sgh g600
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
Jan 03, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
I Cant seems to pail motorola h700 headset to samsung g600
Well, it sounds to me like you know how to get the headset in pairing mode, have you tried turning off your old e900 and then pairing?
This guide was taken from here.
In standby mode, press Menu. Highlight Applications and click Select.
Highlight Bluetooth and click Select, or just press 4.
Highlight My devices and click Select, or just press 2.
Put your remote device into pairing mode. You can find out how to do this from the manual that came with the device. When the device is in pairing mode, highlight Search new device and click Select.
If Bluetooth is not activated on your G600, you'll be prompted to switch it on. Click Yes.
The G600 will search for all the Bluetooth devices in the proximity. The type of device will be indicated by the icon to the left of it, so you can clearly see if the device is a PC, a phone or a remote headset.
You'll be asked to enter the PIN number to connect to the device. This is in the documentation that came with the remote device but if in doubt, try 1234 or 0000, as these are the most common PINs.
Once connected, the device's icon will turn orange on the My devices screen, and when you press the red End call key to return to standby mode, you'll see the headphone icon on the top row of the screen.
Your headset will now be paired permanently with your G600. Switch the device off to disconnect it, and next time you switch it on the phone will connect automatically, providing your Blueooth is activated (go to Menu, Applications, Bluetooth, Activation, On to activate Bluetooth).
My apologies for the copy past guide, I have never used a samsung phone.
Dec 25, 2008 | Motorola Mobility H700 Wireless Headset
switch the phone on without a sim card,
type in *2767*2878# WAIT for it to reset,
once it boots up itself, the phone code is now gone,
if the phone is asking for a SIM LOCK password
then send it to someone who has the equipment to unlock it
Feb 01, 2008 | Samsung SGH-D600 Cellular Phone
Samsung SGH-G600 Cellular Phone Logo
161 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
