Question about Musso Lussino Dessert Maker 4080 1.5 Quart Ice Cream Maker
I have a musso ice cream maker - it is 7 years old and the paddle does not turn anymore- i think i could be the switch button- where do i send it for repair- is it worth it? j
4 Suggested Answers
  • 4 Answers
SOURCE: Musso Switch
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Posted on Jun 04, 2009
  • 4 Answers
SOURCE: Musso Ice cream maker freezes and then heats up during use
  • 586 Answers
SOURCE: I need to replace the
Hello there,
To replace the churn switch,
  1. first thing you should do is to unplug the ice cream maker for the power outlet.
  2. And make sure the ice maker is turned off before you unplug it from the power outlet.
  3. Then you remove the ice cream bowl,
  4. try to wiggle off the mixer blade assembly bofore the bowl,
  5. then you turn to the side of the machine, then you unscrew the screws that are visible to you,
  6. then you unscrew the covering of the switch,
  7. then you will have access to the switch on the main panel, then you can take it out and replace it with a new one,
  8. then reverse the process to reassemble it back together, make sure you turn off the switch before plugging it back to the power outlet.
Hope this helped. All the best Elect_Comp
Posted on Sep 23, 2011
I have a Musso L2 or L2A ice cream maker. I am searching for a service manual with a list of replacement parts.
Suleiman, your directions are not clear -- how do I "wiggle off the mixer blade assembly before the bowl"? I can't get that central spindle to budge no matter how I tap it or wiggle it or pull it or try to unscrew it. I can't take the top off the machine to get at the switch housing inside. Please, can you post a video of how to take apart a Musso Stella ice cream machine?
Sep 19, 2013 | Musso Ice Cream Makers
Just receive this machine and am not sure which switch is the chill land which switch is the churn!
Simple. The churn button is the one with the swirl on it (i.e. indicating churn). The chill button just looks like a snowflake.
Jun 25, 2010 | Musso Lussino Dessert Maker 4080 1.5 Quart...
Paddle does not move. Machine is about two years old.
sometimes the brushes take a set when unused.. Unplug the motor. Without using rnough pressure yo break anything, try turning the motor by hand using the paddle. You will be trying to turn the motor through ithe gesrs so use slow steady moderate pressure. This does work. as long as you watch what you are doing wiyh yhe force you apply. Good Luck. and enjoy the ice cream
Sep 07, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Need manual for musso 4080 lussino desert maker
I cannot find a manual, but if you go this website you will get info on your machine and tons of ice cream ideas to use with your Musso machine. http://www.makeicecream.com/muslusicecre.html
Jun 11, 2009 | Musso Lussino Dessert Maker 4080 1.5 Quart...
I need to buy a new Ice cream well/ bowl
Apr 29, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Mixing arm/bowl will not turn once machine is turned on
The only thing I can really suggest is to make sure the easy-lock button is fitted into the right place on the lid, and to make sure that the ice cream mixture is not too thick. But, if the turning paddle is locked into place properly, and the mixture is still in liquid form, then there is a problem with one of several parts - could be the metal sliding switch or even a motorized part. These parts cannot be replaced. It is worth a shot to replace the mixing paddle - the unit has a 3-year warranty, so I would Call Cuisinart to get the part instead of ordering it online - they may or may not give it to you for free. If the new mixing paddle still won't spin, get the unit replaced either thorugh the store (depending on the store -each has a different policy) or get it replaced directly through Cuisinart. This model is actually pretty solid, so a second one shouldn't give you any problems.
-Tha Mp3 Doctor
Mar 05, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice Cream not freezing
Yes, they stop working sometimes. Same thing happened to me.
The Cuisinart ICE-20 bowl is precisely the same, and works with the Krups 337. You can buy the Cuisinart bowl separately. It costs nearly as much as the whole machine, but what can you do.
Jun 26, 2008 | Krups 358-70 La Glaciere 1.5 Quart Ice...
Musso Switch
Mar 18, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Jan 14, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Musso gelato maker where can i buy parts
Oct 31, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Musso Lussino Dessert Maker 4080 1.5 Quart Ice Cream Maker Logo
80 people viewed this question
Top Musso Ice Cream Makers Experts
ray gallant
Are you a Musso Ice Cream Maker Expert? Answer questions, earn points and help others
