Technics output IC SVI 3206A. Would anyone have any idea where a guy could find one of these without having to buy 20 of them @ a smooth 115$ a pop?
  • 3,904 Answers
Check out Allied Electronics...if they don't have it then they will be able to steer you the right direction.
Posted on Jan 28, 2013
SU-G91 amp over load wont reset.
Technics SuG91 uses a couple of SVI ( I think they are SVI ) packs for driving the speakers. These are big black plastic things mounted to the silver finned heat sinks. 95 % of the time, this is the problem. They are not very tolerant to any type of abuse, and all the amp has to do is overheat once and they are toast. 1 The SVI packs are expensive and that amp may not be worth fixing. If you know how to de-solder something, and are comfortable working with voltages that can kill you, you can unplug the amp, make sure it has been unplugged for at least 20 minutes, and gain access to the area of the circuit board that the SVI packs are soldered to. De-solder one of the packs and remove it from the unit. Make sure that when you de-soldered the SVI pack that you DID NOT accidentally solder one solder hole to another ( create a connection from one hole to another that shouldnt be there ) . Re-assemble the unit correctly, plug it in and turn it on. If the display lights up, you have removed the offending unit and need another one. If it is still in protection, then mark the one you took out as "possibly good", and repeat the removal procedure for the other SVI pack. NOTE if you decide to replace the SVI pack yourself, you will need heat sink compound ( that goo that stuck the original pack to the heat sink ). you will need to remove the old stuff ( a rag and some alcohol will work ) before you apply new heat sink compound. If you are uncomfortable with ANY OF THAT, then take it to a shop that offers free estimates. Good luck and BE CAREFUL....Rob
May 06, 2015 | Technics Audio Players & Recorders
Svi 3204
From your question, I don't know if you're looking for an amp board, or preamp board. These two functions may be covered by multiple boards.In any case, they are no longer available. Your unit would need to be troubleshot by a competent audio tech to the component level. If you need more assistance, or would like to inquire about a repair, please visit my website, audioserviceclinic.com. Thank you.
Jun 15, 2014 | Technics Audio Players & Recorders
Svi 3204
If these are model numbers,you would need the part number of the IC. If the IC is specific to Technics, it is most likely to be unavailable. If you would like more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
My father in-law just gave me a stereo system he wasnt using. It came with a technic suv98 amp. I hooked up everything but there is no sound coming out. The output indicators are not even showing...
Checked your amplifier connection, it supposed to be like this, amplifier has 2 audio connectors RED is Right White is Left channel, connectors cable should be connect to audio output of the receiver/DVD/CD etc.. and the other end of the cable connect to the input of the amplifier. hope this help thanks
Dec 04, 2010 | Technics SUV500 2-Channel Amplifier
Technics amp SU-X999. I need an output I.C type SVI-4004
NAother option is to fix a universal amplifier kit into the set which powers from the same voltage preferrably a MOSFET drive which are very much available in the market and can be suited into the set. They will alos be very effficient but take care tto do the fixing mechanically , connecct the right power and groung with good shielding. Disconnect the old amp totally and use the power lines that come to the IC. I hope this works for you. Good day
Jul 30, 2010 | Technics Audio Players & Recorders
I am trying to locate a replacement SVI 3023 IC, as used in Technics SA-R230L Tuner/Amplifier. Thanks, Dave.
The SVI3203 is no longer available. If you can find an SVI3205 (it too is no longer available), you can substitute. Where are you located?
Dan
Jan 14, 2010 | Technics Audio Players & Recorders
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
94 people viewed this question
 Grubhead
Grubhead
