Question about Lands Phones
Answering machine won't pick up incoming calls
I took a new ATT EL42208 cordless phone with answering machine and hooked it up in one of our rooms and it worked fine. A week later, I moved it to the kitchen. The phone works, but the answering machine doesn't pick up calls. I tried all of AT&T's good troubleshooting suggestions, but none solved the problem. I have the feeling that the phone jack wires, which are connected fine and working (B, Y, R, G) need to be adjusted somehow to accommodate the answering machine. I can't see how the wires are connected on the back side of the first jack we had it connected to, and I don't want to take it apart.
SOURCE: Problem with ATT cordless phone set (3 phones)
i just replugged the phone jack in again,, made sure it was in right,, that solved my problem,, hope this helps,, pretty simple hey,, oh well, i hope it is as simple for you..
Posted on Jan 29, 2008
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
marketex
  • 371 Answers
SOURCE: phone won't ring with incoming calls
Thanks for your attention
Posted on Apr 18, 2009
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
I wonder if any one who asked this question got an answer to this good question. I am having the same problem. I need some help.
Gene
Posted on Jan 20, 2010
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
ATT JUST INSTALLED UVERSE. PHONES WILL NOT RING AND ANSWERING MACHINE DOES NOT RECORD LEFT MESSAGES
The best thing to do is to call them back and have them send someone over. sounds like it was not setup the right way. They should have made sure eveything works before they left.
Feb 01, 2014 | Panasonic KX-TD7896 Cordless Phone
How do I set the number of rings before the answering machine picks up on a Vtech CS6114 cordless handset?
The CS6114 isn't an answering machine. It won't pick up any calls on its own.
If you have an answering machine attached, refer to the documentation for that machine or else repost your question specifying the make and model of your answering machine.
If you subscribe to an answering service provided by your phone company, contact them for information and help.
Sep 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
No Dial tone on any of the phones, unable to answer incoming call however answering machine is able to pick up. Model TRU12803
I received a reply in a quick and to the point matter. It took only a couple of minutes and the problem was fixed. Thank you very much
Apr 29, 2009 | Uniden 5.8GHz Cordless Phone
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Lands Phones Logo
1,365 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
