Question about HP LaserJet CP6015n Colour Laser 512MB 1200x600dpi 41pp... Printer
HP 6015 49.FF95 ERROR - HP LaserJet CP6015n Colour Laser 512MB 1200x600dpi 41pp... Printer
pdouglasss
  • 125 Answers
SOURCE: support
49.XXXX
PRINTER ERROR
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file.
hope this helps you
pdouglasss
Posted on Jan 10, 2009
pdouglasss
  • 125 Answers
SOURCE: 49. FF95 error
Hi hasan_taff:
What model HP is it?
Posted on Apr 04, 2009
  • 82 Answers
SOURCE: 49.ff95 service error
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
Posted on Dec 08, 2009
iron_luiggi
  • 91 Answers
SOURCE: A problem with HP Laserjet 2420
X PRINTER ERROR A firmware error occurred 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter. This error is usually caused by a bad formatter board.
Posted on Apr 07, 2010
indus3
  • 212 Answers
SOURCE: I get an error in HP LaserJet 4345 MFP printer,
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Posted on Apr 21, 2010
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
FF95 SERVICE ERROR CODE IN PRINTER
Does it give a 49.FF95? As their is no such error code "FF95" for a HP 2420. However I've seen 49. XXXX error codes before (XXXX meaning weird Alphanumeric Characters and numbers). This type of error code you can try a couple of Items:
1st - Perform a Cold Reset:
1. Turn the printer off.
2. Hold down the SELECT button, and then turn the printer on. Continue holding down
the SELECT button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW button or the DOWN ARROW button until COLD RESET is highlighted.
4. Press the SELECT button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values
If the machine still comes back to the Strange FF95 error I would start with the replacement of the formatter,
Part Number for the Formatter:
Network versions Q3955-60003
Non-network versions Q3953-60001
Hope this helps..
Feb 25, 2011 | HP LaserJet 2420 Printer
49.ff95 service error is coming in my printer. what i have to do?
Go to HP web site :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412123&prodTypeId=18972&prodSeriesId=416419&swLang=8&taskId=135&swEnvOID=54
download the newest firmware and upgrade the printer firmware.
Jun 15, 2010 | HP LaserJet 2420 Printer
Dec 08, 2009 | HP LaserJet 2420dn Printer
Go to HP.com. In the Support section you will find documents to help you troubleshoot this problem.
Oct 08, 2009 | HP LaserJet 2420dn Printer
Hp5200
how to open the printer
Apr 06, 2009 | HP Hewlett Packard LaserJet 5200 Printer
49. FF95 error
Hi hasan_taff:
Apr 04, 2009 | HP LaserJet M4345xs All-In-One Printer
49.FF95 SERVICE ERROR HAVE ANY SOLUTION
I have an HP Laserjet 2420 printer. And it's really bothering alot, it has an error 13.06.00 and also 13.20.00. What shall i do? I tired to clean the falg sensor and replaced the end sensor, but still there is no progress. Please i need help ASAP.
Jun 03, 2008 | HP LaserJet 2420dn Printer
SHOWS FF95 ERROR MESSAGE
This error is due to corrupt firmware or the correct network connectivity.
Please upgrade the firmware of the printer by following the link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
- Let me know once done
- Nikhil
May 31, 2008 | HP LaserJet 2420dn Printer
Printer error
What make of printer, what model. Under what conditions does the error occur? Please give at least some detail.
Oct 10, 2007 | Office Equipment & Supplies
HP LaserJet CP6015n Colour Laser  512MB 1200x600dpi 41pp... Printer Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
