Question about Palm Treo 650 Handheld
Can not sync palm treo 650 with vista
I have moved my palm treo 650 from xp to vista. It will not sync with the PC
    Problem Solver:
  • 6 Answers
Download active sync and install, also make sure its running on the pda itself
Posted on Jan 25, 2009
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
Apr 28, 2009 | Palm Treo 650 Handheld
Need to download software to sync my PalmOne Tungsten E2 to my PC
Here is the link for the Palm Desktop manager and Hotsync software for Windows. There is a link on the page for Mac if needed.
Palm Desktop 6.2
  • Palm Centro; Treo 755p , 700p, 680, 650; Palm TX, Z22; Tungsten E2
  • Windows Vista, Windows XP, Windows Media Center Edition 2005,kb=PalmSupportKB,t=ooccase,case=obj(32859)
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Suncing Media, Photos, Videos and MP3
The Palm Desktop Manager, which is free on the Palm website, can sync all your media to and from your phone. Here is the site, just choose the right OS for your computer.
When you sync your phone to your PC, it will ask you initially for what you want to sync. You can also do this anytime when you open up the Palm Desktop Manager on your PC. You can drag and drop your MP3s to the music folder on the Palm Desktop Manager and then sync it to your phone. This is the easiest way to get the MP3s on your phone.
You can also move photos/MP3s from your phone to your PC by using a 1GB SD card (the TREO 650 cannot accept any size larger than 1GB, trust me!). Copy your photos/videos/MP3s from your phone to the SD card and then take the card out of your phone. Use a USB Card Reader and connect it to your PC to read the SD card you just removed.
Good luck.
Apr 20, 2008 | Palm Treo 650 Handheld
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Outlook Calendar synchronization failed in palm treo 650
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Feb 24, 2008 | Palm Treo 650 Handheld
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Treo 650 Sync w/ Outlook 2003
Please try the following: 1. Pop the Software Installation disk that came with your treo into your pc and allow it to autoplay. 2. After the disk begins playing, you will be prompted to choose your language-do so. 3. After a second a new dialog box will appear-Select the option "Change your syncronization method" 4. Select "Use Microsoft Outlook to manage Calendar, contacts, tasks and more. 5. Perform a hotsync 6. Open your versamail and hit the sync button
Sep 19, 2005 | Palm Treo 650 Handheld
Treo 650..In contacts, how do I delete many at a time instead of one at a time
I suggest that you create an additional subfolder under your main contacts for your master contact list and use the main contacts file as your list for syncing with your treo. Once you have your contacts moved around you need to change your setting on the sync to have your pc override the handheld. I use pocket mirror to sync with and it's a fairly simple setting to change. I would also suggest that you export your contacts to a back up .pst file before doing the sync. If it messes up on you with duplicates or something you can alwaws just delete the contacts and import them from your back up. I recently cleaned up my duplicates on a treo 600 using this method.
Sep 12, 2005 | Palm Treo 650 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
141 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
