Question about Coralvue Reef Octopus BH90 Hang on Protein Skimmer
Is my Octopus BH90 Skimmer to big for my 15 gallon tank?
I have a 15 gallon reef setup. 4 pices of coral 20lb of live rock 20lb of live sand
Abiotic factors for coral reef
Temperature and sunlight are two abiotic factors found in nearly every ecosystem, but since the Great Barrier Reef is an aquatic ecosystem, it has some additional abiotic components, including buoyancy, viscosity, light , salts, gases and waterdensity.
The Major Biotic & Abiotic Components of the Ecosystem of the Great ...
oureverydaylife.com/major-biotic-abiotic-components-ecosystem-great-barrier-reef-316... Abiotic factors for coral reef Google Search ..i hope this is what your are asking for.
Nov 30, 2016 | Cell Phones
What is the Berlin Sump?
The Berlin Sump is the most basic type of aquarium sumps and consists of a 20-30 gallon tank, protein skimmer, live rock, and a pump.
Sep 05, 2012 | Fish
Can I use OZONE in my Euro-reef protein skimmer?
Absolutely, all Euro-Reef protein skimmers are safe for use with ozone.
Aug 30, 2012 | A H Fabrications Fish
Can I use sea sand as a substrate in my aquarium?
You should not use sea sand. Sean sand is often contaminated and will pollute the water in your tank. The small shells and tiny pieces of coral mixed into the sand will inevitably raise the pH level of your aquarium.
Aug 28, 2012 | Aquaculture Fish
Where can I buy aquarium lights and accessories online?
I bought all of my aquarium equipment from http://www.marinedepot.com they also got quality aquarium lighting and lighting accessories in decent prices, you should check up their site.
Aug 21, 2012 | Fish
What kind of lighting do I need for my saltwater aquarium?
This depends on what you will be keeping in your tank. If there will be only fish, you will not need intense lighting. Usually, the fixture that comes with the aquarium should be sufficient. However, if you plan on keeping reef inside your tank you will need to consider your lighting options. The proper lighting in a reef tank will have considerable effect on coral growth and coloration. The main factors you need to take into consideration are light intensity, spectrum and tank inhabitants.
Aug 14, 2012 | Fish
How much live rock should I have in my aquarium?
Live rocks require one to two pounds per gallon, depending on the dimensions of the tank and the density of the rock. I won't suggest you this system if you have a heavily populated fish tank.
Aug 02, 2012 | Fish
I have a 55 gallon tank. What size water pump do I need?
A standard 55 gallontank needs at least 550gph of water circulation. The minimum acceptable water flow for afreshwater aquarium is 10x the tank volume per hour. For saltwater aquariums without corals, thereshould also be a 10-15x tank volume for circulation. As long as the pump you get follows theseguidelines, the itself won't matter.
May 13, 2012 | Fish
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Coralvue Reef Octopus BH90 Hang on Protein Skimmer Logo
81 people viewed this question
Top Coralvue Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Coralvue Fish Expert? Answer questions, earn points and help others
