Question about Dishwashers
Loudness of dishwasher
Our Kenmore dishwasher is so loud we can barely hear ourselves speak. Do you have any suggestions?
  • 10,515 Answers
T turned out to be the fan on the motor/pump assembly came loose and made a whirring sound. The fix involved replacing the entire pump/motor assembly as it was a "unitized" assembly.
Solution by one of the experts to all kenmore dishwasher owners.
Posted on Jan 25, 2009
  • 100 Answers
Is this a high pitch squeek or noise. If so its because it isnt getting used enough. Dish washers need to be used 1-2 times a week. If noise starts when you first start the cycle and then goes away its because of the seals. a little lemon juice helps keep them lubed. I think there are products that help with this. I hope it wasnt more serious than this.
    Brigadier General:
  • 8,619 Answers
Hi
It could be because of the following :
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
  • Rylee Smith
    Rylee Smith Jan 25, 2009
    Heater fan
    If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
    Pump
    Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
    To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
    Thanks
    Rylee
    Genius:
  • 1,199 Answers
Was it always loud ?or did it just start!
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
How To Fix Volume Issues on Headphones?
open sound settings in windows system settings ?
Jun 13, 2014 | Gateway Computers & Internet
How can I increase the loudness of the CDs burned on the internal CD-RW drive?
You can use a free software audio editing and recording program called Audacity. Using this program load your stereo track(s) into Audacity, then look in the effects menu and select normalize. Make sure to set highest loudness level to 0 db, which is the maximum digital volume level. You can hear the difference in volume when you use the test button. If you can't still get enough over all volume level with the normalize feature then you will need to compress and limit the stereo track, but I don't suggest getting your over all loudness levels that high because it ruins and lowers the dynamics of your music. Another words when you compress and boost the over all loudness of your album then all your music is at the same highest audio level which is very ear fatiguing. It may sound better to you at first at louder volume levels but you will quickly learn to hate it over time because it does not sound natural. That is why most music today is all about loudness and ear fatigue. And because of the loudness wars going on today every Record company is trying to have the loudest album out there thinking it will sell more copies. It is all false baloney, it really should be about the quality and dynamics of your sound instead of how loud it is.
May 23, 2013 | Fostex MR16HD/CD Digital Recorder
I can not hear the music loudly but i used to
perhaps you changed profile settings, please read instructions manual to apply loudness set.
Oct 31, 2011 | Sony Ericsson Cell Phones
On my toshiba n305 notebook speaker sound is barely audible even at highest volume level. it is fine with earphones. tried everything. is it designed that way or something can be done? thanks
If you're on Vista/Windows 7, follow these instructions to enable Loudness Equalization. This significantly boosted the volume of my laptop speakers.
Start Menu -> Control Panel -> Hardware and Sound -> Sound
Double click on your default sound device (it will have a green check on its icon). Go to the Enhancements tab. Check Loudness Equalization, and hit apply. That should boost up any super-quiet noises.
Mar 07, 2011 | Computers & Internet
Sears kenmore dishwasher model 665-13752 k601/ runs noisey
I'm afraid I just had a repair man in for the same problem. We just bought ours in July, 2008, and there is a bad berring in the motor. We have to replace the motor assembly ($244). Told that it is just the luck of the draw if the motor is faulty or not; no quality in products anymore. We were also warned against using it til it's fixed as it could overheat and melt things, flood water all over the floor, etc.
Feb 16, 2009 | Kenmore Dishwashers
Volume of my voice on Motorola V170 trakphone
the phone's Microphone or Microphone IC is faulty. replace the Mic its under this place. or even just clean it maybe some dust would defect it.
.please rate this post as good as u can so we can help others.
Feb 02, 2009 | Motorola Mobility RAZR V3
Noise, Noise, NOISE
Barring an actual cat being inside the dishwasher, I would surmise that the motor bearings are starved for lubricant, which is something that is not normally done. Sounds like its time for a new dishwasher
May 27, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
567 people viewed this question
Top Dishwashers Experts
